Power door lock actuators - Ford Powerstroke Diesel Forum
Old 07-20-2010, 01:27 PM
I have a 99 extra cab 250.My power door lock actuators quit working for the second time.Last time I put in used ones and only got about a year.
Are there any trick that I can do to keep em working?
Should I just nut up and buy 2 new ones?
Suggestions please.
Old 07-20-2010, 02:02 PM
My dad's truck has a similar problem... he was telling me about reading a mod that basically places aluminum foil over a resistor in the door somewhere that fixes the problem. I'm not positive, but I'll see if I can dig up the write up. I have one going weak in my crew cab that only works properly when it wants to, so I need to find the write-up anyway.
Old 07-20-2010, 02:10 PM
Boom! -
Well, it won't let me link it, but its on *************"dot"com
Just google "ford door lock actuator repair" and it will be the first site returned.
Really I can't write Diesel Bombers as one word here?
Old 07-20-2010, 04:40 PM
Cool thanks bro ,I'm gonna try it right now.
Old 07-20-2010, 04:44 PM
aluminum tubing engineer
yup...tin foil over the resistor thing-y
Old 07-20-2010, 05:21 PM
I have the same truck as you. And my door lock actuators stopped working as well. I did the foil trick and it bought me about 3 months. So I just bought twoo new ones off of rockauto.com for about 50 bucks shipped and its been about 6 months and their working great still. I would just buy new ones cause it was a pita to do the whole foil thing for them to quit working just a bit later. But hey I've also heard the foil trick worked for a couple people on here for a while
Old 07-20-2010, 06:02 PM
I did one about 3 years ago and the other about 1 year ago. Completely worth it.
Old 07-20-2010, 08:13 PM
I cut pennies to fit instead of using foil, did all 4 doors last spring, still working, although the passenger front door sometimes makes funny noises. good fix for $.04!
Old 07-20-2010, 08:41 PM
If you read that article, the component lets the signal go through, but protects the motor from burning up. Be aware that putting the foil (or pennies) in there does let more signal through, but also takes away any protection the device provides.
Just throwing it out - your decision on whether you do it or not.
Old 07-20-2010, 09:39 PM
^As long as you're not holding the switch down constantly, you're not going to burn up the motors.
