Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Interior Discussion
Old 04-16-2006, 01:01 PM
trrun trrun is offline
dashlight bulbs
Does anybody have a part # on the dash bulbs, I'm looking to replace mine with LED bulbs but need to know the part # unfortunately they don't list it in the owners manual says to contact dealer for replacement. So any help would be appreciated.
Thanks Tim
Old 04-16-2006, 01:39 PM
Brian Brian is offline
bulbs
bulbs
here are bulbs for a 99 f350, i am taking a wild guess as to what year your truck is.
link to led 12volt bulbs
1999 FORD F250-F550 (With replaceable halogen capsules)
High & low beam headlamp
9007
9007ST Silverstar High Performance Lighting: the whitest and brightest Halogen
9007XV XtraVision Halogen Upgrade: Up to 20% Brighter
9007CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9007LL Long Life Halogen Upgrade: Lasts 3x longer
Parking light
3157LL
Front turn signal
3157LL
Rear turn signal
3157LL
Tail light
3157LL
Stop light
3157LL
High mount stop light
922
Fog/Driving light
9006
9006ST Silverstar High Performance Lighting: the whitest and brightest Halogen
9006XV XtraVision Halogen Upgrade: Up to 20% Brighter
9006CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
9145
9145ST Silverstar High Performance Lighting: the whitest and brightest Halogen
License plate
168
Back up light
3156LL
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Ash tray
161
Glove box
161
Dome light
578
912
Step/Courtesy light
168
Trunk/Cargo area
906
Under hood light
912
Instrument-general
194
37
Check engine indicator
194
Hi-beam indicator
194
Seat belt indicator
194
Brake warning
194
Automatic transmission indicator
194
Directional signal indicator
194
__________________________________________________ __
The applications presented in this replacement guide have been compiled using the best information available from the vehicle manufacturers at the time of your search. This guide is intended for general information purposes only, not to be construed as any type of warrantee as to any particular application. For specific applications the vehicle owner's manual should be consulted.
Old 04-16-2006, 01:58 PM
hey thanks for the reply mines a 02 f-350 wonder if the instrument cluster bulbs are the same part# as your 99?
Thanks Tim
Old 04-16-2006, 02:00 PM
mschn99 mschn99 is offline
Banished
Thanks Tim
they shoud be the same tim......and what do ya think....i think 099f350 and superstroke should get the title of "reasearcher extrordinare".....
Old 04-16-2006, 02:52 PM
hey marc how hard is it to get the dash apart to get to those bulbs?
And yeah they should get that title, and you must have diesel running through your viens to work on them all day and then come home and answer ?'s about them guess its better than hating your job right?
Tim
Old 04-16-2006, 03:04 PM
purduefarmboy460 purduefarmboy460 is offline
Send a message via AIM to purduefarmboy460
I took mine out one night cause I was bored and didn't have anything better to do. it didn't take that long. Just scary like anything else envolving plastic. The piece around the radio, instruments, etc, pops pretty good when it comes loose. I don't suppose it took me more than half hour to have the instrument cluster laying on the work bench. I think it all started cause there was dust on the guages that I couldn't get to
I used a putty knife and started on the right end of the dash to pop it loose. you want your wheel down as far as it will go, and you'll have to drop it into 1st gear if you have an automatic. Once you get your fingers in behind the plastic piece, it pops right off along there. Be sure to disconnect your powerpoint, it has a short harness. I think the only tools I used were the putty knife and a hex driver to take out the cluster.
hope that helps!!!!
Old 04-16-2006, 03:35 PM
Banished
Tim
farmboy is right....its not that bad.....you will need a 7mm socket or nut driver.....and some kind of a non sharp, think utinsal to pry with. also, if you take the time to remove the plastic cover from the steering column....its easier to get the trim and cluster off, but thats not something you absolutely have to do.....there are three electrical connectors after you get everythig unbolted on the back of the cluster.....and then changing hte bulbs is as easy as twisting out the sockets.........Marc
Old 04-16-2006, 03:39 PM
do either of you know aprox. # of bulbs control the instrument cluster?
Thanks Tim
Old 04-16-2006, 03:43 PM
Banished
fords picture on the dealer website is tellin me six....but for some reason i want to say there are eight illumination bulbs........i cant remember for sure though........Marc
Old 04-16-2006, 03:57 PM
hey thanks marc i'm going to order some tonight just wanted to know how many so i only have to pull it apart once .
Tim
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
