King ranch seats
I have a 2001 extended cab F250 with a bench front seat. Would I be able to fit a newer (and how much newer can I go?) set of front seats in. I know that this question was somewhat answered in an earlier thread, but I'm also asking if I can fit king ranch or lariat bucket seats with the center console in my truck with it having a bench for OE. Also will any of the power options work (mine are manual) As far as the heated seats or power seats? Thanks for the comments.
I THINK! The seats should match up no problem out of a 99 to 2007. As far as the power options, some trucks (mine) have manual buckets but there is an electrical connection under the seat for a more optioned truck. Yours may not be wired for heat but should have a power hookup for the power adjustments. The plugs may not match but you should be able to make them work.
And as for the center console.
and if the plugs are different, can you just splice in a new plug?
The center console should bolt in as well (sorry i didn;t clarify that in the first post) As far as the plug, I would just sit down with a meter and a fused power supply and figure out the seat and truck then splice in either a factory plug or make my own 'harness' I say make your own because I have a feeling you may have to run a whole new feed for the heating side of the seat. But I am not sure about that.
Thanks a lot man.
