Side window leak - Ford Powerstroke Diesel Forum
Old 06-04-2010, 07:31 PM
Side window leak
I have a 2002 F250 Lariat extended cab and the little window is leaking around the seal and the window is not very tight. Any way to adjust that gasket?
Old 06-04-2010, 07:42 PM
Make sure the latch is tight against the window and add a little vasaline to the gasket where you think the leak is.
