Pulling off the steering column cover? - Ford Powerstroke Diesel Forum
Old 04-28-2010, 12:55 PM
Once you go black......
Send a message via MSN to CanadianDiesel
Title says it all...how in the hell do I gain access to all the wiring under there?
Fuse keeps blowing and I'm thinking it's shifter related. Really hoping to see some bare wires!
Thanks
Old 04-28-2010, 01:14 PM
Or if anyone knows how to pull the ignition let me know, that's all that's stopping me.
Old 04-28-2010, 02:57 PM
Old 04-28-2010, 03:06 PM
you can pop the plastic trim off the ignition , or disconnect your batteries turn the ignition on and insert a tool such as an o-ring pick into the hole on the lower column cover ( the one with no screw in it) and push up on the pin , it might require a litle jiggling but you'll fell the pin move up and you'll be able to remove the tumbler assemby
Old 04-28-2010, 03:13 PM
It's that easy? I wasn't sure how it was secured on there. So i'll be able to pop it back on?
Old 04-28-2010, 03:21 PM
yes it can be that easy however the second method is guarenteed not to screw anything up
Old 04-28-2010, 04:38 PM
too late
Old 04-29-2010, 06:11 AM
Which fuse are you blowing? Just FYI there is a common problem with the wire going to the OD switch. Right where it comes out of the shifter column the insulation wears off and shorts out.
Old 04-29-2010, 09:20 AM
You hit the nail on the head
That's the issue I'm having, Fuse #19 keeps blowing as soon as I attempt to shift to Gear 2.
Just got back from work and about to go check it all out.
Thanks for the heads up
Old 04-29-2010, 09:50 AM
fixed!!!
