Dash Light Question - Ford Powerstroke Diesel Forum
Old 04-21-2010, 07:49 AM
Dash Light Question
My 2001 F250 dash appears to have a burn bulb or two. At night, the center of the dash is noticably bright than the edges but isn't really bright enough. Are these bulbs hard to get at or relatively simple?
Old 04-21-2010, 08:10 AM
This is just what I got done doing. Just pull the dash cover off. It is held up by clips so you just pull it off. Then there are 4 screws that hold the cluster up. I think they are 7mm. Then, just pull it out some and there are 5 bulbs and I recommend replacing all 5, while you have it apart. The bulbs are 194.
Old 04-21-2010, 09:56 AM
Wow... Thanks!
Old 04-21-2010, 10:43 AM
DJM DJM is offline
Im also going to be doin this this weekend ordered LED's to put in there from ford little over 6 bucks a piece.
