Interchange info please - Ford Powerstroke Diesel Forum
Old 04-08-2010, 05:09 AM
Can anyone confirm what interchange there is for a 01 SD Steering Column, floor shifter, w/ tilt? All I keep finding is interchange for 98-00, and 02-07. Kind of looking like the 01 is some how special? I want to change from column shift to floor shift with the least amount of hassle.
Thanks.
Old 04-12-2010, 06:46 AM
Old 04-19-2010, 06:40 AM
Old 04-19-2010, 07:01 AM
Ihre Mama mag mich
should be the same through 99-04 the only thing youll need yo look at is the part numbers for the steering gear box if its the same for the 99 as it is for the 00 then right as rain if not youll need to "press" the yolk off the corresponding steering shaft to fit your gear box..there were a fue years having adiffrent spline count....
ozone-etr1
Old 04-19-2010, 07:17 AM
Thanks. I was worried about wiring, lockouts, conections, etc. Want the change to go as easy as possible.
Thanks again for the info.
Old 04-19-2010, 07:21 AM
Ihre Mama mag mich
Well now...make shure if yours has all that cruse an buttons then the new one falls in line too...but the ignition switch and harness will move from your current one to the new one so the keying will be the same..un bolt one install in to the other...
