Just checking my wiring work here for the 08, I'll post up the 02 as well. This is getting cold confusing and could use some help.
Here is what I'm working with.
Key switch:
1. Yellow/red -
2. Purple/white -
3. Blue/gray - key sense (I think)
4. Black - ground (I'm pretty sure)
Clockspring
1. Purple/brown - air bag driver 1 (pos or neg?)
2. Black/purple - ground (cross car beam, 3rd stud)
3. Yellow/red - relay horn
4. Yellow/green - air bag driver 1 (pos or neg?)
5. Blue/white - audio switch redundant audio
6. Grey/yellow - switch redundant audio
7. Green/brown - speed control command return
8. White - speed control command
9. Purple/white - I think this is illum (not sure)
Leftside of column (think ignition)
1. Blue/red (larger gauge, thinking constant 12v)
2. Blue/white - starter (I think)
3. Blue/gray
4. White/orange - ignition 1 (I think)
5. brown/yellow - accessory, heater blower 1 (I think)
6. Purple - accessory (says it supposed to be purple/green, mine is just purple)
multi function switch
1. Brown/yellow - hazards
2. Purple/white - turn left
3. Gray/yellow - turn right
4. Green/brown - flash to pass
5. White/orange - high beam
6. Black/gray - ground (cross car beam, 2nd stud)
7. Purple/orange - wipers (high)
8. Gray/brown - wiper washer
9. Purple/white - wiper interval B (faster or slower?)
10. Green/purple - wiper interval A (faster or slower?)
11. Black/gray - ground (cross car beam, 2nd stud)
12. Blue/orange - wiper interval C (faster or slower?)
Tow/haul (top of column)
1. Yellow/grey - fuse 25 or circuit breaker
2. Brown/yellow - tow mode control
Shift interlock
2. Green - transmission park detect
3. Blue/orange - brake shift interlock
All are pictured below. I'm looking for simple terms. I'm not great at wiring and diagrams are somewhat confusing. Thanks for the help in advance.
Sent from my Nexus 6 using Tapatalk
