Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Interior Discussion
Old 10-27-2009, 01:25 PM
ms8091 ms8091 is offline
power door lock actuator
Does anyone have an idea how to remove the power door lock actuator in a 1999 f250 ext. cab? Is it a real pain or is it a fairly simple project? Thanks
Old 10-27-2009, 02:09 PM
JSchuricht JSchuricht is offline
It is a pain, but not too difficult.
Borrowed from acedrew at diesel bombers (first hit on Google)
Remove the door panel, not going to go into detail here, just to say there are 2 screws, one under the lock/window control panel, and one behind the marker light lens.
Remove the 3 Torx screws around the latch, seen on the edge of the door, be careful, these are very tight and from what I've read everywhere, strip easily...
Remove all the linkage from the latch assembly
Follow the lock rod down from the top of the door, it goes horizontal then turns into the actuator assembly, there is a small plastic clip that flips off the rod radially around it.
The interior handle cable does not need to be removed.
The exterior handle linkage is a threaded rod that has a plastic clip holding it on, it is easily flipped open.
A the very back of the assembly you will feel another rod, it runs behind the threaded rod, this is the one that messed me up for a minute.. simply follow it up, it terminates in another plastic clip, stick a long screwdriver through a hole further up the door, and pry one of the catches open to remove the rod.
Unplug both cables, the door lock actuator and the latch sensor.
You should now be able to pull the whole assembly out past the vertical brace.
The actuator is removed by prying on a plastic clip on the rear of the assembly
Old 10-27-2009, 03:52 PM
Thank you, that doesn't seem too bad, just hope I don't break anything in there.
