Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Interior Discussion
Old 07-09-2009, 07:23 AM
loanman loanman is offline
steering wheel replacement?
My steering wheel on my 2001 F-250 is thrashed and I would like to replace it. How difficult is it to replace these steering wheels?
where is the best place to find one?
thanks for your help
Old 10-24-2009, 11:58 AM
DieselNoob DieselNoob is online now
Bringing this back from the dead because I'm also interested in knowing this. Mine is toast.
Old 10-24-2009, 06:08 PM
blowinsmoke7.3 blowinsmoke7.3 is offline
Me as well
Old 10-24-2009, 06:12 PM
Ewils35 Ewils35 is offline
Send a message via AIM to Ewils35
check the salvage yards for a decent wheel. you can always unplug and unbolt ur air bag and put it into ur new wheel.
Old 11-11-2009, 06:46 AM
smokenstroke smokenstroke is offline
Also needing a leather wheel!
Old 11-11-2009, 07:03 AM
TUGGER TUGGER is offline
Hello guys
I agree check the salvage yards for a decent wheel
when removing a steering wheel remember
don't forget to disconnect the batteries before starting to replace the air bag equipped steering wheel to avoid a nasty headache
be certain to index the wheel and spline I use a felt tip pen
you will need a puller to remove the wheel from the splined steering shaft
do not hammer the wheel back on that can damage bearing in the column
use a small amount of anti-seize compound and tighten the retaining nut slowly
Old 11-19-2009, 06:51 PM
fifty fifty is offline
and tap the brakes a couple times to depower the airbag module...(after the batteries are unplugged)
Old 11-19-2009, 06:54 PM
nolimit nolimit is offline
can you use the newer air bag 05-07 on the older models 99-03. the one with the blue oval.
