Originally Posted by RJacks258
You know, I'm not trying to start anything, but I'll say it. I think someone mentioned something like this to you once before maschn99, you seem to find the negative in everything. Everytime there is a post you are the first to shoot it down. You may be more knowledgable about somethings then others on this forum or maybe you might not be. But how about a little positive reinforcement or letting people know the goods and the bads about a project. Nope you go right for the kill.
if it wasnt for the PCM controll of the actuator that controlls the whole boost level of the turbo, id be interested in seing how it could be mounted, but unless you have a degree in computer programming, this simply sounds unfeasable......please, ask overloard what he thinks of the idea....im not being negative, im being realistic. i wasnt the only guy to shoot the supercharger idea down as not being benificial in the end.....and as far as the big oil, i was skeptical at first and did a lot of research from numerous people before i posted a solid opinion on that. there are a lot of ideas out there, and im sure someone somewhere has messed with a variable vain turbo on a 7.3, but that particular turbo is not possible in any way i can think of for your truck, if it wasnt for the PCM controll, it would be interesting to see the mounting and oil system retrofit, but it would be possible, and i would be very curious to see what it would be like since that style of trubo is so smooth and consistant with boost.
another note....im pretty thick skinned.....you can say whatever you would like to me as long as its not personal. i dont take offence to much, and you kinda sounded like you were being carefull with what you said above. that comment was not a personal attack and was just your opinion....and if you would like i will refrain from posting on your ideas.....but you dont need to tip toe around me......call it like ya see it as far as im concerned...too much political correctness for me in this world as it is
.......Marc
