dyno #s
I had my truck dynoed over the weekend just wanted to see if anybody thought these numbers were around what to be expected. Its a 00 w/ a manual trans. I have a TN BB, TW chip, 5in straight pipe, afe stage 2, banks ic, on the extreme setting it made 285hp and 650tq. Has anybody else got similar numbers w/ close to this setup. Any suggestions.
i put out 280 and 645 the other day with my mods in the sig
sounds low with a turbo you should have tried another setting
did you run it in 5th or 6th?
I would have thought you would be around 300-310 |
Next time turn the chip down. I would bet your running out of HPOP on the extream setting. You should have been in the 300-320 range.
Does the tq seem to be in range and the hp low or is the tq low also b/c i expected maybe 300-320 on hp and tq within the range it was. I should have tried the chip down a setting but didnt. I also suspect that i am running out of oil on the high setting it created a enromous out of black smoke. Im goin to go w/ a adrenaline hpop and a set of hybrids next. I guess we will see what happens sometime after that.
Does seem a tad low but not bad. You do know TN Turbos are junk right? A stocker moves more air LOL.
But how where everyone elses numbers for the day and what type of dyno was it on? |
Again... You spew stuff about products you have never ran... I did 467hp 1050tq with that "junk" TN BB. Now thats not your wounder 520... But you had larger hybrids, ported heads, and who knows how much time live tuning...
I was just giving him a hard time calm down. and you know my 1st run on the dyno b4 it was even touched that day was over 500.
I actually really like my TN ive had no probs. w/ it and it def. moves more air then the stock one and no fn surge w/ it as for other trucks I was the only 7.3. but a couple of 6.0s w/ turbos and injectors did in the 400s and 850s tq i wasnt completly displeased compared the more money they had in there trucks. It was a mobile dyno but not sure excatly what kind? Im goin to do Hybrids, upgrade the hpop and a few other things untill Ford brings out their 6.7 and then look for one of those. So i can put on the back glass FORD MAKES IT AND FORD SHAKES IT. haha
