Wanting to add 3 more guages - Ford Powerstroke Diesel Forum
Old 06-06-2009, 11:56 PM
OperationSmile.org
Im gonna add three more gauges to my lineup. Already have the typical boost, pyro and trans. I know for sure I am adding fuel pressure, Air pressure (for the rear air bags) and.... Need some opinions on what the third should be. It will be mounted in a upper dash pod. Thanks
Old 06-06-2009, 11:59 PM
PMR = JUNK
Engine oil temp.
Old 06-07-2009, 12:10 AM
OperationSmile.org
Why engine oil temp?
Old 06-07-2009, 07:49 AM
Send a message via AIM to BlackSmoke&BuckinHorses
How about an oil pressure gauge? So you can acctually see what your engine is doing instead of looking at the stock gauge and its Ok/Not Ok needle position. Just a thought
Old 06-07-2009, 07:59 AM
I was in the same position not too long ago... I decided to go with the scan gauge from Terminator Engineering. You get a whole lot with that bad boy. You can monitor all functions real time plus your able to scan codes, do contribution test, buzz test and record data. Best part is that it's a simple plug in and go.
Old 06-07-2009, 08:13 AM
HPOP gauge
Old 06-07-2009, 08:33 AM
Too cool for school
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
Originally Posted by JAcktheBear3 View Post
HPOP gauge
HPOP gauge x2
your airbags didnt come with gauges? My dad's truck has a panel on the lower dash witha gauge for each side, and the switch to inflate them with in the middle
Old 06-07-2009, 11:34 AM
PMR = JUNK
Because your EOT is pretty important.
Thats a good one too. The stock gauge is basically an idiot light, its either on or off.
Old 06-07-2009, 08:16 PM
I second the engine oli temp.Its always different then the coolant temp.The truck might be almost fully warmed up but the engine oil temp is still only 110-120 so I don't beat on it till it gets up to over 160.And it takes a while even with the 70 degree weather.
Old 06-08-2009, 11:10 AM
Send a message via MSN to Jesse.James
i have oil pressure and water temp
