H2E with stock injectors?
I think my turbo is about to eat $hit. Would a H2E set up require a cab off install? Also would i be able to spool this turbo with stock injectors? I plan on moving to hybrids eventually i just want to make sure my stockers can keep up for now.
the H2E can be installed without removing the cab and a regular H2E will be okay with stockers till you go bigger it will be a little laggy of the line
That is what i thought. I do have a 1.5k resistor on a switch so that will help it spool a little but i need to get a custom burned chip as well.
h2e will work fine, i ran one for awhile with stock injectors.
Are you using the h2e as part of your new twins set up? I am actually planning on moving to twins eventually and if the h2e can be used then that will be another added benefit.
i would run the stock h2e and then when you put more fuel to it mod it
yes, im running a 66mm modded h2e in my twin turbo setup.
whats your low pressure turbo gonna be?
..s495????
