need help asap!!! - Ford Powerstroke Diesel Forum
Old 05-29-2009, 05:11 PM
need help asap!!!
I just installed my dp tuner and now my tuck wont start! I know I saw a thread on this issue,but now I can't find it.Any help........And yes,I did use the search function 1st!!!
Old 05-29-2009, 05:33 PM
not sure but heres a to the top
Old 05-29-2009, 05:42 PM
Man,I know I installed it exactly perfect.I went to reprogram my switch(because my chip got reburned)according to the directions (which I didnt get done) and now the only way I can get the switch to light up is to hold both buttons down with the key off,then switch the key on but when I let go of the buttons to get the blinking 0 it goes blank.Now I can't program the switch to see if its in postion 0(no start) or not????WTF
Old 05-29-2009, 05:45 PM
Almostdunfukinwidit
It was in the truck before and worked correct?
Old 05-29-2009, 05:51 PM
No, I bought it from a buddy and sent it back to jody to get reprogrammed for my truck.jody checked it out and the chip is all good.I really need to figure out whats up with the switch first.It might just be in the 0 postion.The switch was working fine at first but It was taking me a couple tries to reset it for the new tunes and it just quit working.I can get it to light back up but Its not doing like its should.I can't do anything with like it is.
Old 05-29-2009, 05:52 PM
Almostdunfukinwidit
DP-Tuner » FAQ
Check here
Old 05-29-2009, 06:00 PM
Thanks Dave but that was the first the place I looked,lol! I don't know what to do now,I guess I will take it aprt again tommorrow and reinstall and see what happens?
Old 05-29-2009, 06:39 PM
Are you sure you got the contacts nice and clean on the pcm?
Are you sure your chip isn't in the no-start postion?
Old 05-30-2009, 01:50 AM
I'm going to re-clean today and no,I'm not sure it's not in the no start postion.Thats one of my problems,when I was trying to reprogram my switch it went blank during the process.I can make it light up so I know it still works its just not working right.I'm not able to reprogram the switch like it is.I'm going to try a few things in a little while but I have my doubts.If anyone has a similar problem I sure as hell would like to get their input!!
Old 05-30-2009, 05:40 AM
HAHA!!!! Got it working!!!! I finally got the switch to reset and then I was able to find out it was on postion 0.I put it on postion 4(140 aggressive) after a few minutes of warm up and gave her a rev and smoked out the neighbors!!!!! I can't wait to get this switch mounted and donate some rubber chunks to the local asphalt here in nc!!!!!!!!!!!!!!
