100k tune-up - Ford Powerstroke Diesel Forum
Old 05-28-2009, 08:44 PM
100k tune-up
I have a 02 f250, what is done in a 100k mile tune-up?
Old 05-28-2009, 08:51 PM
probly all fluid changes.
Old 05-28-2009, 08:52 PM
Send a message via AIM to xxxjagsfanxxx
oil change and fuel filter to start. then id probably check and make sure ur belts good, no cracks or anything. rotate tires if it hasnt been done lately. grease the front end and u-joints. just little stuff like that i would probably do.
Old 05-28-2009, 08:54 PM
ohh, and if its an automatic id take it to any transmission shoip that has a flush machine and get that done, or if its a manual u could do it urself, just drain and fill. and the same with the differentials.
Old 05-29-2009, 10:32 AM
just read your manual, usually all of the fluid changes should have been done at 90k, every 30k for transfer case and diffs and every 15k or 30k for transmission, then obviously oil if it's needed.
Old 05-29-2009, 10:33 AM
Let's Run'em
Don't forget your spark plugs and new cap and rotor
Old 05-29-2009, 10:44 AM
PMR = JUNK
Damnit i was gonna say that! You forgot plug wires too Julian. Don't forget about your points and condenser too. Might wanna clean the jets in the carburetor too. And your O2 sensors probably need changed.
