ATS HOUSING OR WW - Ford Powerstroke Diesel Forum
Old 05-27-2009, 11:08 AM
ATS HOUSING OR WW
If you had the money to spend on the housing. Would it be better to install it for turbo surge Ive been told that the ww moves less air. but will take care of surge. And the housing would be easier to install . I want to do the housing, just want to make sure that it will take care of the surge thanks andy
Old 05-27-2009, 11:09 AM
I bought the Wicked Wheel just cause of the money issue. I really dont think it will move that much less air to be noticable
Old 05-27-2009, 11:28 AM
Send a message via Yahoo to Big_Stroker
the WW is better for the money.
If you dont care about money then spend the money and just get a 38r and be done with it.
Old 05-27-2009, 12:59 PM
ATS housing. Your stock wheel is more aggressive then the WW.
Old 05-27-2009, 01:42 PM
ww for sure cheap,easy and done.no difference in power between stock and ww.just the ww doesnt surge.
Old 05-27-2009, 01:53 PM
Pony the cash and do the ported housing, or do as stated and go for a complete turbo. Sometimes the WW isnt the answer, but the other two options will DEFINENTLY eliminate the surge.
Bottom line is this. A WW is a step back to perhaps cure or at least help alleviate surge. a housing or turbo is a leap forward to eliminate surge once and for all. Just MHO.
Old 05-27-2009, 03:31 PM
get the ww or a diff turbo .
Old 05-27-2009, 03:44 PM
I would just put the money towards a better turbo and get the WW.
Old 05-28-2009, 01:08 PM
Got Whistle?
Feedback Score: 5 reviews
Depends on what your goals are. If you aren't going to build the motor and keep the stock turbo, def get the ATS housing. The WW does not cure surge. Some say it helps them, bu those are the folks that didn't have it bad to begin with. The housing is the ONLY 100% cure for surge.
