Stock limited slip rebuild...
Well I couldn't find a drive-train section so move this if needed...
My tires are beginning to get low now and I am felling a desire for wear-like-iron highway tires after having my A/T's. I do need to use my truck off pavement often enough, so here is my situation: Many on here are pushing the Tru-Trac Limited Slip carrier as their weapon of choice. Being very budget minded, and being I already have a L/S, I have heard you can rebuild the stock Unit to a stronger/tighter spec. Does anyone have any more information on this? Thanks Powerstroke-Gods! |
Bump to the top!
I had a locker in my last chevy that actually locked. If I was going to do anything to improve the LS on this Ford it would first be to replace the diff fluid without the LS additive, and then it would be a locking diff upgrade. I don't care if it is an air locker, electric locker, or ratchet style so long as the wheels lock. That was a great deal.
try this
Ford limited slip rebuild |
I need to do the same thing, smoke on the pavement, one tire, spin them in the dirt, both tires
The link above doesn't tell us how to rebuild, just what parts to get. Anyone else done this?
Thanks |
The Ford LS get a bad wrap because they don't work the way they come from Ford and the reason being is Ford puts way to much friction modifier in the fluid. They call for 8 oz, when I changed my fluid I put 3 oz in and did some tight figure eights, if you have chatter in the rear end you need to add 1 more oz and do it again, do this until the chatter stops. The LS works great now. I have done this to about 6 different PSD's and 5oz was the most any of them took. Most were good with 3-4oz, this is why I never recommend fluid that has the modifier already in it like amsoil.
NCH |
oOo I didn't know that. Do you know of any synthetics that don't come with modifier?
bump
alright i went to carquest yesterday and picked up some stuff that valvoline makes its full synthetic and doesn't have any additives im gonna give it a try along with that stuff from the stealership
