First mods on new to me 7.3L - Ford Powerstroke Diesel Forum
Old 05-25-2009, 07:57 PM
MRS MRS is offline
I just bought a 2001 7.3L CCSB F350 with 65,000 miles on the clock. After some research, I thought that I would do some mods/replacements once I baseline the usual PM items.
1. 6.0L HD transmission cooler and in-line filter
2. Ford Severe Duty AIS and filter
3. EGT and Transmission temp gauges and CPS
4. Possible Dynatrac front hub and bearing replacement kit
I don't want to go racing - done that. Want a super-reliable, cool running tow vehicle for my Airstream.
Any comments, omissions?
Thanks
Mike
Old 05-27-2009, 09:14 AM
You'll want to do something with the stock exhaust. If you like it as quiet as stock then a Walker BTM muffler should replace your OEM muffler. If you like it a bit louder then you can either replace the stock muffler with a straight pipe or replace the whole exhaust with one of the very common 4" kits. The OEM muffler has got to go, it has severe internal restrictions. I really like my free flow 4" system and it was only about 300$.
I tow a Nash trailer and a trans cooler upgrade is a must so I'm glad to see you have it.
Don't worry about the fancy hub upgrade. That's a lot of money for a small improvement in reliability.
Old 05-27-2009, 01:33 PM
MRS MRS is offline
Thanks for the comments. Seems like I hit most of the bases. I think some mods on intake and exhaust will benefit performance and mileage. I'll look at replacing the muffler with a Walker BTM
Is a larger intake behind the AIS a good idea? How about the cut-out and fender foam idea -- does it provide good sealing and improve flow significantly? Is it a compromise on filtration?
Thanks,
M
Old 05-27-2009, 01:47 PM
Yeah, if your going to stay with stock tires then I wouldn't worry about the dynatrac. You can do the DIY mod for the intake and save some cash over the ford system
Old 05-27-2009, 02:04 PM
Amen. The 6637/Tymar/BHAF filter is a good solid fiscally efficient upgrade alternative to the rather expensive AIS. Other than that, it seems you are on the right track mod wise... HOWEVER. Seriously consider a Transgo HD2 or even Tugger kit, or a BTS or John Wood Valve body to compliment your tranny cooler upgrade at the very least, if you want a good solid tow beast. Youll thank us later.
1. Gauges
2. Exhaust
3. Intake
4. Transmission cooler/ Transmission VB or SK at least.
5. Good chip with a tow tune if desired
