EV vs. Performax - Ford Powerstroke Diesel Forum
Old 05-24-2009, 01:24 PM
EV vs. Performax
Right now im runnin the EV series gauge from Isspro, are the performax the best gauge series right now?
The lighting on my EV's isnt to bright and its hard to read at night. I've seen At the time i ordered them, i loved the blue and chrome color they had now i dont
I want a factory look, do they offer a gauge like that on the Performax series
Old 05-24-2009, 02:08 PM
Performax is the top of the line gauge from ISSPRO, but you could get the same brilliance of illumination from the EV2 line. Both EV2 and Performax are stepper motor heads with LED illumination, both come in White Face, Blue Illumination and the chrome bezel
If you need more help on the subject just ask
Old 05-24-2009, 04:14 PM
Go to Isspro.com and look at the gauge styles... You can get a perfect match in both the EV-2 and the Performax line...
You can also add LED's to your gauges you have now and they will really brighten them up...
First pic is your gauges with LED's, Second is with normal bulb...
and the third one is just for fun... 17 Performax gauges...
EV vs. Performax-drive-oil-pressure.jpg   EV vs. Performax-p6100042.jpg   EV vs. Performax-hq-final-gauges.jpg
Old 05-25-2009, 09:54 AM
Wll if i could add LED's like you said and brighten them up like yours it would really help, but i thought the EV already came with LED bulbs
Where can i get the bulbs, Isspro? I also want to get a 4 gauge pod and get a fuel pressure gague do they have one in the EV series?
Thanks
Old 05-25-2009, 02:17 PM
Bump to the top
Old 05-26-2009, 11:15 AM
The blue LEDs for the existing EV series (which comes with regular incandescent bulbs) are here:
ISSPRO Product Categories - need two of these each for trans temp & pyro
ISSPRO Product Categories - need one of these for boost.
I would opt for an EVē electric fuel pressure gauge. We have mechanical in the EV series, but then you have to mess around with the isolator. The EVē and Performax series are all LED backlit.
Regards,
Michael Pliska
Old 05-26-2009, 11:25 AM
17 GAUGES . dam does one give a heartbeat readout
Old 05-26-2009, 02:16 PM
Regards,
Michael Pliska
Thanks. I definately will get the LED's.
Im still debating on getting rid of my Ev's and upgrading to 7 Performax gauges, look like some really nice gauges
What would be a good combo of 7 to run? Of course Boost, Pyro, Tranny, and Fuel Pressure are a definate. Would put those 4 on a pillar mount. What would be a good combo for the other 3? I was thinkin HPOP pressure and 2 others??
Old 05-26-2009, 02:28 PM
My choices in no particular order...
Pyro, Tranny, boost, manifold or drive pressure, fuel pressure, HPOP pressure, oil pressure, oil temp, water temp, rear diff temp, volts, and so on...
Old 05-26-2009, 02:45 PM
theres 12 choices there, i only was lookin at 7 gauges
What would be the 5th, 6th, and 7th most important gagues after Tranny, Boost, Pyro, and Fuel Pressure?
