NEED HELP, GIANT LOSS OF BOOST - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-19-2009, 02:08 PM Thread Starter
causethechicksdigit's Avatar
Unhappy NEED HELP, GIANT LOSS OF BOOST
okay, i put one of the wicked wheels in today, before the wheel i was pushing 34 lbs of boost, now i can barley push 24 lbs of boost, i got told i shouldnt lose boost like that, i have went over it twice now and cant figure it out, the only thing i can think of is that while it was off i had to twist and turnt the wasgate can by the compressor housing to get it off so would that do this and if so what do i do to correct it
Late 99 7.3L Stroke, 4in Turbo Back with 6in Stack, 75&140 HP 2 Position Chip, Boost Fooler, Foil Delete, GDS Fuel Spring, Intake, WW,4 inch suspension lift with drop pitman and drop track bar bracket, 35x12.5x16" on stock rims
causethechicksdigit is offline
post #2 of 16 Old 05-19-2009, 02:10 PM
rankroddin250's Avatar
disconnect the waste gate?
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #3 of 16 Old 05-19-2009, 02:11 PM Thread Starter
already is, i checked it first thinkin i must have put it back on, i have everything the exact same as when i had the stock wheel in it
post #4 of 16 Old 05-19-2009, 02:55 PM
adjust your wastegate some more? does it run any worse?
groomzybanshee is offline
post #5 of 16 Old 05-19-2009, 02:58 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Check for boost leaks and shaft play. At 34 psi that stock turbo didnt have long to live the way it is
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #6 of 16 Old 05-19-2009, 02:58 PM
Lifetime Premium Member
jbeasts10's Avatar
I lost about 4lbs boost when I installed mine aswell.I was at 30 to 31lbs,,now it stays around 26 to 27lbs.
2001 F250.Custom Tuned,Ball-Buster Turbo,5"Exhaust
ITP Reg.Return,TD Billet Converter,Built Tranny,Snow Meth/Water Stage 2..plus a few more things!!She will Hunt
jbeasts10 is offline
post #7 of 16 Old 05-19-2009, 03:17 PM Thread Starter
im going to play with the wastgate, and there aint any shaft play at all, and i have checked my gauge tubing, and all the gaskets around the turbo and cant find a single leak, i kinda assumed i would lose a pound or two possibly but not ten
post #8 of 16 Old 05-19-2009, 03:19 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
How about your intercooler boots? Did you check those?
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #9 of 16 Old 05-19-2009, 03:40 PM Thread Starter
wastegate doesnt do anything to help or hurt, and yes i did check all the intercooler boots and i checked the spider boots too, is there anything else im overlooking possibly that would make the boost pressure drop 10lbs.
post #10 of 16 Old 05-19-2009, 04:34 PM
no-tel-in's Avatar
i lost about 3-4 lbs after my install.
2000 F-250 4x4 7.3
BTS Transmission - 6.0L Cooler
GTP38r
Full Fuel System with Return
2-Stage W/M & Nitrous
Adrenaline HPOP
238/100's
no-tel-in is offline
