Isspro performax install ?'s - Ford Powerstroke Diesel Forum
Old 05-09-2009, 04:58 AM
Question Isspro performax install ?'s
Ok, so I am started on my gauge install and have all my wires routed from the esv box into the cab. WTF do I do with the blue wire for the "mode" button?
The directions are not clear on this "mode" button part.
I am thinking the yellow wire and the blue wire are to be attatched to an optional normally open switch to control re-call and dimmer funtion.
Am I right or not even close? Please help............
Also, should I remove intake before tapping for boost sensor? or try the AIH delete and intall there? Or be lazy and splice into map line??
Old 05-09-2009, 05:36 AM
Powerstroke Junkie
I haven't used the performax series , I only use the EV's. I would try and call Isspro or the place you bought them from. Isspro may have a PDF on their site? Google is your friend, hint ( Isspro Performax Install Directions)
NCH
Old 05-09-2009, 05:50 AM
We'll see what happens. I did the google thing, but will prob call someone today. Diesel manor has after hours support, but I didn't want to call at 11pm my time. These performax are a little different beast.....................
Old 05-09-2009, 07:31 PM
The mode button goes to a momentary ground switch. A push button works best, press and release and everything goes to its max reading stored...
The dimmer goes to your dimmer wire, just like any other guage...
