Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 01-24-2007, 06:06 PM
stroker03 stroker03 is offline
Home brew high idle????????????
i found the instructions on how to do the mod but a i was wondering if anyone has pics on how to do it? and if there were different ways to do it?
thanks stroker
Old 01-24-2007, 06:13 PM
stump0331 stump0331 is offline
SNAFUSTUMP‹^›‹(•¿•)›‹^›
Tournaments Won: 1
didnt think it could be done on the 7.3, i thought something had to be bought for that motor
Old 01-24-2007, 06:14 PM
sent you the link
Old 01-24-2007, 06:27 PM
JPLTrucking JPLTrucking is offline
Ive done it for my 02 7.3. Works like a charm. Much cheaper than the ford AIC.
Tournaments Won: 1
i stand corrected
Old 01-24-2007, 06:30 PM
how does it work does it just work of the e-break? and only go to 1000rpms or is it adjustable??? like the dodge high idle?????
Old 01-24-2007, 06:34 PM
I'm not sure which link you are looking at, but the one I did is a swithc on the dash with an LED to show when its on. Inder the dash I mounted a potentiometer which adjusts the idle speed. The wires hook to the wires coming out of the gas pedal. Send me the link you have, so I can see if it's the same one.
Old 01-24-2007, 06:36 PM
pm sent..........
Old 01-24-2007, 06:41 PM
Marty Marty is offline
International Threat
I'm sure you could also do like I did with an old GM - choke cable from dash to engine bay and just pull that beotch out! haha...
Stroker03 = can you post those instructions on here on how to do it? I might look into that since I was about to pay lik 35 bucks for the position on my DP chip lol.
Old 01-24-2007, 06:45 PM
How's this
Originally Posted by FormanES
These are instructions for the obs, it might work for yours
A u x i l i a r y I d l e C o n t r o l l e r
AIC MOD
by Sparky
Ok to start off with you will have to go to Radio Shack or similar store and get some parts.
Single Pole Single Throw Switch. Radio Shack pt# 275-612
5K Linear Taper Potentiometer. Radio Shack pt# 271-1714
Linear PART # for the 2K is Radio Shack pt# 900-8587
2 Single Pole Double Throw Auto Relays Radio Shack pt# 900-2391
2 Wiring Harness Plugs Radio Shack pt# 900-2396
18 Gauge Wire
SOLDER
Wire Ties
Butt Connectors
Soldering Gun
Safety Glasses
STEP 1 Switches
Find a power source that is with the key.
Run a wire from there to one side of the switch.
From the other side of the switch run a wire to the coil terminal of both relays
From the other side coil terminals on the relays run a wire to the parking break switch wire. (There is only one wire on the parking brake.)
STEP 2 Idle Validation Switch (IVS)
As you look at the throttle pedal you will see a switch on the left side with 2 wires going to it. The wires are taped together carefully un-tape them so you can work with the wires. I used a razor knife to cut the tape, but be careful not to cut the wires. (There should be a red/orange with and a brown wire, unless they changed the color code of these wires.)
Cut the red/orange wire leaving plenty on the switch side so that you can splice onto it. The red/orange wire that is going into the wire bundle needs to get hooked to the common side of one of the relays.
The other red/orange (the one attached to the IVS) goes to the NORMALLY CLOSED CONTACT (NC) of the relay. Now take a wire from the NORMALLY OPEN CONTACT (NO) and run it over to the brown wire by the IVS, you will just tap onto this wire so you don’t need to cut it. Just take some of the insulation off and solder it on, then tape her back up.
STEP 3 The other Relay and the Throttle Position Sensor (TPS)
Throttle Position Sensor (TPS) is located on top of the pedal and has 3 wires going to it. Remove the tape to expose the wires. (There should be a brown/white wire and a gray/white wire.)
Cut the brown/white wire, leaving enough to work with by the switch. Hook the end up that goes back into the wire bundle to the common side of the other relay.
Take the side that goes to the switch and hook it to the NORMALLY CLOSED CONTACT (NC) of the relay.
Take a wire from the NORMALLY OPEN CONTACT (NO) of the relay and go to the left terminal on the POT.
Now take a wire from the center terminal of the POT and tap it into the gray/white wire.
Tape up all the bare wires and enjoy
OBS= Old Body Style. The 1994-1997 powerstrokes were considered "Old Body Style"
