trans gauge - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-05-2009, 06:15 PM Thread Starter
trans gauge
installing a new set of guages on a 99 and was wondering were the best place was to install the sending unit for the tranny temp also what is the upper limit for temp?thanks in advance for any info!!!
hops is offline
post #2 of 6 Old 05-05-2009, 06:19 PM
Raul@Stealth Automotive's Avatar
here you go: http://stealth-automotive.com/docume...%20Install.pdf
that will show you the test port to install the trans temp gauge...
for that year you dont want to see anything hotter than 200
-Raul
Raul@Stealth Automotive is offline
post #3 of 6 Old 05-05-2009, 06:30 PM Thread Starter
thanks for the very quick reply !!!
hops is offline
post #4 of 6 Old 05-05-2009, 06:31 PM
np bud let me know if you have any other questions
-Raul
post #5 of 6 Old 05-06-2009, 08:07 AM
Powerstroke Junkie
NCHornet's Avatar
Ford considers anything under 230 perfectly normal. Heck their trans gauge don't even show warm until 280!!! That is why they shouldn't even be looked at. Sustained temps over 200 would tell me I want more cooling, but I sure wouldn't pull over at 200. Pull over time for me is 220. BTW The warmest I have seen mine is 190 and that was backing up a 10K TT uphill for about 40 min in 95 degree ambient. All I am running is the single 6.0 cooler.
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #6 of 6 Old 05-06-2009, 09:45 AM
CSIPSD's Avatar
NCH
Agreed. 200 just means its time to look for added cooling.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
