gauges - Ford Powerstroke Diesel Forum
Old 05-05-2009, 03:08 PM
gauges
Looking into getting a chip and some gauges, my brother has glowshift on his 12v and im looking at those. But my question is what does the stock turbo run for boost? Im not sure to get the 35 or the 60. If it wont ever go past 35 with the stock turbo i will get that. Also, what is the max you want to run your egt? There is a 2400 and 1500 deg gauge. I think i want the 1500 right?
Old 05-05-2009, 03:21 PM
35psi is fine... You dont need a boost/vac gauge...
1500 is fine on the EGT gauge as well.
I prefer Isspro gauges myself. Better quality, more accurate and made right here in the portland area.
Old 05-05-2009, 03:26 PM
ok i will look into them as well
Old 05-05-2009, 03:27 PM
If it aint a CAT itsa DOG
I also run isspro's. I am very pleased with them. They look factory and thats what i like best. I have a 35psi boost and a 1500 pyro. My truck only has an intake and exhaust and i build around 17psi max. You don't want to run your egt's over 1100-1200 for very long.
Old 05-05-2009, 03:29 PM
thats what i thought my brothers 12v hits 1500 if he hammers it and he said thats very bad. Im looking into a tw chip too so i think that will up my boost
Old 05-05-2009, 03:35 PM
Here is the link to my pics of my gauges if you want to check em out.
new gauge pics!
Old 05-05-2009, 04:06 PM
As far as the EGT's go...
IH (people that make our motor) say 1250 is the red line... You can tow all day at 1250 and not hurt a thing other then your pocket book from the fuel bill. You can go over 1250 for as long as you feel comfortable with, if you have been at 600 for the last few hours and come up on a pass and want to pull over it, going over 1250 for 20-30 seconds is fine. But if you have been lugging it for an hour at 1100, its not going to take nearly as long to get to the 1250 mark.
Your watching EGT's to protect the pistons, not the turbo. Also keep in mind there are oil cooling jets that spray the bottom of the pistons with oil. This helps keep them below the 1250-1300 danger area.
Old 05-05-2009, 04:09 PM
Theres some good info. Thanks for posting that up CSIPSD. I knew i was close.
Old 05-05-2009, 04:18 PM
new gauge pics!
i like where u put your trans temp gauge
Old 05-05-2009, 04:23 PM
Isspro makes some nice gauges.. thats what i would get....
