5 k mod question
i did the 5 k mod and it worked. i then read that the 4.7 k made the overboost ses light go away but it didnt. i was wondering though if i could put a switch on the resistor to turn it off and on because i have a stick it makes it real rough and jerky at low rpm with all that power. or would the wires mess with the amount of electricity being stopped by the resistor?
Yes you can put it on a switch.
I did mine to and want to put a switch on it to can some one put up a write up on it? B/c I don't do well it wireing thanks
k thanks. a switch is easy to put on. u need to cut the resitor in half with each half poking out of the two hole it does in. then you have to run a wire from each of the two peices of resistor poking out of the plug. thenconnect to two wires in your truck with a switch. the switch simply breaks the conection
So just cut it in half run a wirer from each one to a switch? Cool thanks going to do it right now. I can just use a on and off switch right? Sorry for all the lame ? I just don't do wirine or elec. Thank again
ya that should work. its been raining for like 4 days straight so i gotta wait to put the switch on mine but let me no how it goes.
All you need it a SPST switch. One wire from the ICP to the switch , one from the switch back to the ICP. It will not matter which of the two wires you place the resistor in. When the switch is off the the circuit is broken. If you use a DPDT switch you could use two different resistors Like a 10k on one pole and a 5k on the other if you want a diagram on that let me know.
rook that would be great if you would post up a write up thanks man
