Pulling the Turbo - Ford Powerstroke Diesel Forum
Old 05-03-2009, 04:32 PM
Pulling the Turbo
I am going to pull my turbo out and install a turbine housing, but i was just wondering what the benifit of a wastegate was. I am going to have to disconnect it and if i have troubles with it can i just remove it and leave it off or do i really need it on there to keep from overboosting? Will it hurt my turbo to have it off? Also I am getting ride of my edge and getting gauges and a PHP chip.
Old 05-03-2009, 05:05 PM
do most people see problems with overboost with no wastegate?
Old 05-03-2009, 05:06 PM
John Wood Nut Swinger
What size housing are you installing? 1.0 or 1.15?
Define overboosting? 26psi, 28psi, 30psi,,,,,,,,,?
Old 05-03-2009, 05:16 PM
i am installing a 1.0 housing. well i dont even know if i will even see that much boost with the mods that i have in my sig minus the edge and adding a php chip with probably max 120 setting.
Old 05-03-2009, 05:21 PM
Lifetime Premium Member
I have mine disconnected and see 28 to 30lbs (stock turbo),,if I mat the pedal.
Old 05-03-2009, 05:25 PM
what is a dangerous psi on a stock turbo? should i worry about it?
Old 05-03-2009, 05:27 PM
about 30lbs from what I am told.
Old 05-03-2009, 05:28 PM
Danger zone for longevity is over 28psi, in my experience.
1.0 housing with stock injectors and a hot tune will make 34psi(+/-) so be careful on how often you take it that high.
Old 05-03-2009, 05:43 PM
wow i cant even hardly make 25 psi with my current set up. i cant wait for my new chip now.
