blow off valves?? - Ford Powerstroke Diesel Forum
Old 04-30-2009, 09:08 AM
blow off valves??
Does anyone know if and where I could get blow off valves for my PSD?
Old 04-30-2009, 09:10 AM
why do you want a bov? bov's are for ricers
Old 04-30-2009, 09:12 AM
I, 1, 2, 1/2, 6
uh-oh... It begins again...
Old 04-30-2009, 09:15 AM
I, 1, 2, 1/2, 6
and to contribute something useful. Yes, there are BOV's for these trucks. The ones you'd want to look at are on the pricey side, but it's worth the money to have a quality piece. ALSO, if you have an auto tranny, its not gonna have the effect you want, unless you want to let off the gas whenever the tranny shifts
Old 04-30-2009, 09:27 AM
This may be a dumb question but what exactly does a bov do? I thought they were usually only used on higher hp trucks
Old 04-30-2009, 09:29 AM
I think that when you reach a certain boost pressure it just blows the valve and releases the extra pressure
Old 04-30-2009, 09:33 AM
I, 1, 2, 1/2, 6
it releases boost pressure between shifts so you don't damage your turbo. Cause if you let off the gas too shift, your throttle will be closed so the boost will hit the closed throttle and go back at the turbo, the BOV releases the pressure to avoid turbo damage from the boost hitting it and either causing it to stop or spin the other direction which is bad for it, leads to increased wear
Old 04-30-2009, 09:36 AM
Originally Posted by 6point0damn2004 View Post
it releases boost pressure between shifts so you don't damage your turbo. Cause if you let off the gas too shift, your throttle will be closed so the boost will hit the closed throttle and go back at the turbo, the BOV releases the pressure to avoid turbo damage.
ah ok makes sense now
Old 04-30-2009, 09:39 AM
BLOW OFF VALVE!!!
blow off
blow-off valve
Happy reading
Old 04-30-2009, 09:49 AM
Thanks for clearing that up, wasnt exactly sure because i have never wanted one and im not a ricer
