Wiring 2 EGT probes to 1 gauge ??? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-29-2009, 11:28 AM Thread Starter
I bought my truck with a autometer pyro with the EGT probe in the downpipe. The previous owner welded the bung onto the downpipe, and now the probe doesnt want to come out.
Option 1)
I could just not use that probe, since its stuck in there, and I have a new probe to put in the manifold.
Option 2) I could somehow wire the two different probes to a switch, and use the same gauge. I could switch from manifold pyro to downpipe pyro when i want to.
I dont want to buy another gauge as it takes up more space and costs more money. I would liek to do option 2.
Has anyone had any experience wiring up two probes to 1 gauge? Autometer is no help as they say that the voltage between the red and yellow wire is so small that adding a switch and another prob will distort that number and cause the gauge to be inaccurate. I have a feeling this is possible. Help please.
2003 7.3L
DP Tuner
9.5" lift
37" Toyos
JW Trans
Vegistrokin
optx002 is offline
post #2 of 5 Old 04-29-2009, 11:32 AM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
Ask Jake. He would know the best.
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #3 of 5 Old 04-29-2009, 12:17 PM
szyd's Avatar
Auto meter is right. Any resistance to such a small voltage will distort the reading. A switch would cause resistance.
Youre best bet is to either leave it there and not use it or cut the bung off and weld the hole shut and not use it. Or you could leave it till you buy another guage.
Dale
99.5 F 350 Totaled
2000 F350 Lariate
CC
SB
4x4
4" turbo back
cold air. Zoodad
Banks big head
Wicked wheel
4" BDS lift. With Bilstein's
all brought together by TW
szyd is offline
post #4 of 5 Old 04-29-2009, 12:19 PM
dzchey21's Avatar
I think that stewart warner makes a dual sweep pyro...
single turbo'd 6.4
dzchey21 is offline
post #5 of 5 Old 04-29-2009, 12:28 PM
CSIPSD's Avatar
You cant do it, it will change the reading on the gauge. You can just order a new probe and install it to your old gauge.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
