How much BOOST? - Ford Powerstroke Diesel Forum
Old 04-28-2009, 03:55 PM
How much BOOST?
How much boost should 2000 7.3L PSD produce? The truck has an aftermarket intake, 4" exhaust, map fooler, gauges and just installed a TW chip. The best I can get out of it is on street mode and it will only boost about 17psi max. Is this normal?
Old 04-28-2009, 03:59 PM
wriott
Guest
Posts: n/a
Mine will peg 30 PSI with leaking up pipes. i also have stage 2 injectors also. but yours sound like is running on the low side. check for leaks at all of your boots and at your up pipes
Old 04-28-2009, 04:02 PM
Too cool for school
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
you have a wicked wheel?
Old 04-28-2009, 04:18 PM
Dont think so, all of the engine is stock except for the add-ons
Old 04-28-2009, 04:21 PM
Too cool for school
WW wouldn't hurt. If you don't have any surge i wouldn't worry about it unless your stock wheel takes a crap
check your IC boots it sounds like you have a boost leak
should be between 22-27 mine would push 25-27 when i had just the intake exhaust chip. shes pushin 40+ now with injectors and turbo
Old 04-28-2009, 04:34 PM
Lifetime Premium Member
I would think you should be around 25 to 27Psi..I am right at 30psi.with roughly the same set -up.
Old 04-28-2009, 06:25 PM
yea thats way low im gettin 30-33 with the same setup
Old 04-28-2009, 06:26 PM
you have a leak somewhere.... i would easily see 30psi+ with my setup...
check all your hoses and check to make sure you dont have an exhaust leak on the up pipes
-Raul
Old 04-28-2009, 06:41 PM
OperationSmile.org
I hit 31 with that same setup. You have a leak. Check your IC boots, up pipes and make sure your Boost guage is working properly. Where are you tapped into for the Boost guage?
