Condensation in my Tranny temp gauge
I've had the gauge for a couple months. I have three on the pillar, tranny on top. I haven't yet figured out any rhyme or reason to it. sometimes the trans temp gauge has condensation on the inside of the glass - maybe it's done it three times in two months. it doesn't show up until i start the truck, and it clears up in about ten minutes afterwards and looks crystal clean. this morning it was about 48 degrees and damp outside when it happened. i haven't noticed either of the other gauges (EGT and Boost) doing this. anyone have any ideas?
btw they are auto meter pro comp.one theory i have is that the engine's heat at startup is coming through the firewall at the point where the guage wires all enter. Last edited by samiam; 04-28-2009 at 09:21 AM. |
shoot maybe i shoulda posted this in the general discussion...
maybe a bit of water leaking in your windshield and into it?
Sounds like a bad gauge to me
i wouldn't think that the gauges should allow any water in. might have been manufactured near a faucet?
That gauge should be sealed, but where is the moisture coming from. You may have a couple issues, a bad gauge and a windshield leak. They are known to leak on the drivers side, so check down below for any wetness and then call AM and have them send you a new gauge!!
NCH |
Mine did the same thing twice in the past two weeks. It was the only one of my 3 gauges that did it. It's on the top of the pillar. Hasn't had a problem since. I figured it was just a fluke or something. The gauge works fine still.
Dave |
