Boost Relief Valve? - Ford Powerstroke Diesel Forum
Old 04-27-2009, 10:25 AM
Boost Relief Valve?
Would this help? Does anyone have this?
eBay Motors: 94-03 Ford Powerstroke DieselSite Boost Relief Valve (item 120410466966 end time May-02-09 19:09:33 PDT)
Old 04-27-2009, 10:32 AM
wriott
Guest
Posts: n/a
go to home depot or lowes and get a pressure regulator (one for an air compressor) and make your own for about $22
Old 04-27-2009, 10:34 AM
wriott
Guest
Posts: n/a
here is the part that you want from home depot
Husky Regulator With Gauge - HDA70900AV at The Home Depot
Old 04-27-2009, 10:37 AM
alright sweet. Is that what you got? does anyone have pics of it hooked up? or a easy way to do it? Thanks a lot
Old 04-27-2009, 10:39 AM
wriott
Guest
Posts: n/a
i can have pics later. i just hooked it to an air compressor (make sure you have the air flowing thru the right way) blocked off the outlet end to build pressure inside the regulator and then adjusted down to about 18PSI. Hook it up between the intake and the MAP sensor, you will need 2 1/4" fittings along with clamps
Old 04-27-2009, 11:09 AM
alright i will have to go out and get it then... but pics would be nice. so i can see what im doing.
Old 04-27-2009, 11:13 AM
wriott
Guest
Posts: n/a
it prob wont be until late when i will be able to get them up.
Old 04-27-2009, 11:23 AM
no problem... im not going to do it today.
Old 04-27-2009, 02:38 PM
Lifetime Premium Member
Hopefully this will help a little
Old 04-27-2009, 04:29 PM
wriott
Guest
Posts: n/a
hey you beat me to it, i guess i wont have to post any pics. nice job on the mount ill have to try it.
