A little reroute of the MAP sensor tubing... - Ford Powerstroke Diesel Forum
Old 04-07-2009, 02:51 PM
I have heard this from a few different sources, that by moving the Map line to the hot side of the IC you will gain a bit in throttle response... I thought it made perfect since, I build boost faster on that side as well as higher numbers. So last night I rerouted it over there.
Just some quick drives from the hotel to the jobsite. It works!
Might try it out if you have the ability...
My only concern is how well the MAP sensor will take to the 300-400 degree air temps that might get seen there...
Old 04-07-2009, 02:59 PM
im interested
Old 04-07-2009, 03:15 PM
Originally Posted by Heartbeatracing View Post
im interested
me too, subscibing
Old 04-07-2009, 03:18 PM
Get a write up on it dude. I am interested!
Old 04-07-2009, 07:25 PM
would this help at all on a stock truck with just a chip.
Old 04-07-2009, 08:58 PM
I dont know, but I cant see where it would hurt. Your going to show boost faster on the hot side then the cold side, as well as higher boost numbers. It will allow the PCM to bring fuel in quicker...
Old 04-07-2009, 09:02 PM
do you think this work the same in an OBS as long as it had an intercooler?
Old 04-08-2009, 02:33 AM
Send a message via AIM to Dieselfever78 Send a message via Yahoo to Dieselfever78
What's the difference between yours and a non intercooled(OBS) truck that is that way and seeing the same or more boost than you ??
My '97 has no form of charged air cooling and swings 40-45+ psi regularly You should get a MAP sensor cooler maybe?
-Michael
Old 04-08-2009, 03:20 AM
Ole White
nice find I might have to try this when I get some free time
Old 04-08-2009, 03:34 AM
Thanks for the tip I will be doing this
Any reason you mounted it where you did. Or does that not matter?
