GTP38R more boost - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-04-2009, 08:07 AM
wriott
Guest
Posts: n/a
Quoted: Post(s)
GTP38R more boost
Just installed the GTP38R into my buddys 2000. We also installed stage 2 sticks with the DP chip, tymar intake, 4" exhaust and some other mods. Right now i am only getting 19PSI (wastegate opening) and was wanting to turn it up to about 30-32 PSI. What is the best way to do this??? adjust the wastgate (what PSI should it open at with handheld pump?) or put a regulator on the wastgate line?? any ther way???
post #2 of 13 Old 04-05-2009, 09:07 AM
wriott
Guest
Posts: n/a
Quoted: Post(s)
nobody knows???
post #3 of 13 Old 04-06-2009, 04:57 AM
OUMX117's Avatar
Turbomaster makes a wastegate control rod that will work with your 38R. It's relatively inexpensive and will work much better than the factory actuator.
SOLD- 2007 F250 Harley 6.0
4.5" lift with 35x12.5-22 Toyo Open Country M/T
SCT X4 with Gearhead SRL, 8k Tow and Unlimited Tow, 4" TB Magnaflow
OUMX117 is offline
post #4 of 13 Old 04-06-2009, 05:36 AM
Cynic
Dirk's Avatar
Sent you a pm. You don't need some expensive wastegate.
Best Car & Motorcycle Insurance | Auto/Moto Protection Today | FREE Trade-In Quote
Voluntary Banishment: Knowing when to leave.
Total Diesel Performance\Unlimited Diesel Performance\Diesel Innovations\BTS\Terminator Engineering\Swamp's Diesel Performance\Black Widow Diesel\Calvert Racing
Dirk is offline
post #5 of 13 Old 04-06-2009, 05:37 AM
Too cool for school
taylorking's Avatar
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
1.15 AR housing?
Typical cummins owner.
taylorking is offline
post #6 of 13 Old 04-06-2009, 02:12 PM
CSIPSD's Avatar
You can ajust the factory WG rod 3-4 turns and try that. Its a pain to do, but there is no reason to buy a new one with the 38R. Stock turbo, thats a differant story.
That being said, the nice thing about the Turbomaster WG rod is it can be ajusted in about 10 seconds to as tight as you want or as loose as you want. Just takes a 10mm wrench and an extention.
The best option IMHO... like said above... 1.15 housing and never look back.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #7 of 13 Old 04-06-2009, 03:14 PM
layson's Avatar
Quoted: 83 Post(s)
what about just disconnecting the red boost line...
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #8 of 13 Old 04-06-2009, 04:18 PM
CSIPSD's Avatar
You could, but I would bet the wastegate is just loose from the factory...
Joe
CSIPSD is offline
post #9 of 13 Old 04-06-2009, 05:23 PM
wriott
Guest
Posts: n/a
Quoted: Post(s)
im gonna be adjusting the wastegate in the nest day or so and see how it works. right now i have th front axle out of the truck working on it so once that is back in (tomorrow sometime) ill adjust it and let everyone know how it came out.
post #10 of 13 Old 08-19-2009, 08:41 PM
Phiber Optik's Avatar
did this end up working for you?
I have a similar issue
What way do you have to turn the rod?
2008 F350 CrewCab ShortBox
Lariat
EGR Delete
Elbow
IC Pipe
4" SS Turbo back exhaust
4" lift with AirBags
17x10 with 37x13.5"
Tri-fold cover
Gearhead Performance Tunes!
Phiber Optik is offline
