After 1300+ dollars, sounds like truck is worse - Ford Powerstroke Diesel Forum
Old 04-02-2009, 07:19 AM
I wanted a little more Azz to pull my racecar trailer. I installed a bunch of stuff, now I have what appears to be surging, sounds like birds flapping there wings, when i get on the gas hard (whenit is floored it seems ok).
So, I haven't made a pull yet, we got rained out last weekend, and I am out of town this weekend, but it apears after what, 1300 buck, i went backwards. Truck pulled fine before, I just wanted a little extra. WTF
Input is welcome, thanks
Old 04-02-2009, 07:21 AM
What did you install?
Old 04-02-2009, 07:22 AM
DP Tuner F5 Chip
(20 tow,40 tow and 60 tow, 80 econo, and 100hp)
AFE Stage 2 Max Flow XP
Foil Delete
Muffler delete
Autometer Pro Comp Ultra-lite Gauges
AIH Delete
JW Valve body has been ordered, should be here in a few weeks
Old 04-02-2009, 07:23 AM
Oh, before upgrades, no surging at all
Now when i get on it, rolling on the throttle, not stabing it, at abou 12 psi it starts to flutter, and auge flutters
Old 04-02-2009, 07:47 AM
Cynic
It was fluttering before, you just hear it now because of the AFE. It is probably a bit worse now due to the chip. You need a ATS ported compressor housing to correct this or install a wicked wheel compressor.
Old 04-02-2009, 07:53 AM
but before i could hear the turbo spool up and never heard it flutter.
I priced one at ITP, 399, are there any others. This can be done without removing turbo.
Old 04-02-2009, 08:27 AM
ITP would be your best bet for that...
You could also install a 1.00 exhaust housing and a WW, those together will get rid of surge 90% of the time.
Yes the ATS housing can be done with the turbo on the truck, but its much easier to do it on a bench.
Old 04-02-2009, 08:38 AM
ADMIN AND TECH
dirk you are so smart
Old 04-02-2009, 08:39 AM
Ok, thanks guys
Old 04-02-2009, 09:20 AM
Cynic
Don't expect me to cuddle unless you buy dinner first...
To the OP: As CSIPSD said, a 1.0 exhaust housing would be good. Especially if you tow. Might as well delete the EBPV pedestal and housing.
