Turbine Housing torque? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-01-2009, 02:52 PM Thread Starter
GreenF350's Avatar
Well, if the weather holds out, this will be the weekend I put my new GT38R, up-pipes and CCV mod in. I think I pretty much have everything under control, hoping to get it done in a long day, but 2 if I have to......but I am changing the exhaust housing on the turbo to the 1.15A/R and was wondering if there is a specific torque to torque housing and/or outlet adapter bolts to or if it is the old "german torque" rule.
Also, should I use threadlocker on them? I'm thinking at least some low-strength stuff if not medium. Thanks.
-Aaron
2000 Ext. Cab F350 SRW, 6" Skyjacker lift on front/8" BDS Springs on rear w/NO blocks, 37x13.50 Nitto Mud Grappler's, Aftermarket Front Bumper
-Always More Stuff Coming!
GreenF350 is offline
post #2 of 8 Old 04-01-2009, 04:12 PM
layson's Avatar
Quoted: 84 Post(s)
When I did mine I just got them as tight as I could with a wrench. You really can't get a torque wrench in there to do it. You will see... Also my cheapo wrenches wouldn't even fit in there... the craftsmen would but not the cheap knock-off brand..
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 8 Old 04-01-2009, 06:00 PM Thread Starter
GreenF350's Avatar
Yeah, I knew there wasn't much room in there. I know at work we have wrenches with a 3/8" drive on one end to use with a ratchet or torque wrench and there is a formula to use for that to get the right torque, but I guess it's not necessary. I figured it could ruin the turbo if the housing came loose and I didn't know if you could distort the housing by getting it too tight. Although after handling the housing today when it came in I am thinking it is pretty stout. Sounds like it will just be getting tightened with a wrench.
Anyone use locktite or just do it dry?
-Aaron
post #4 of 8 Old 04-02-2009, 07:10 AM
benningtonr's Avatar
I think this is the link you are looking for, just enter your information and it will give you the torque setting.
Hope this helps
https://www.motorcraftservice.com/re...la_main_en.asp
2001 F-250 7.3l EC 8' Bed 4X4 Lariat
DP Tuner F5 Chip
(No-Start, Stock, 20 tow, 40 tow and 60 tow, 80 econo, and 100hp)
Autometer Pro Comp Ultra-lite Gauges
(Boost, EGT, Trans temp)
AFE Stage 2 Max Flow XP
Foil Delete
Muffler delete
AIH Delete
Wicked Wheel
Ported Shroud Compressor Housing
HPO X-Over
CCV Mod
JW Valve Body
Billet Triple Disk Converter
Marinco Mod
benningtonr is offline
post #5 of 8 Old 04-02-2009, 04:21 PM Thread Starter
GreenF350's Avatar
I have the formulas at work too, but I like that link and will be keeping it. It looks like a handy link to have.
Layson (or anyone else) did you use locktite on the bolts or just get them good and tight? I know I sound paranoid, but I don't want to spend that kind of money twice just because I didn't get all the info. Thanks.
-Aaron
post #6 of 8 Old 04-02-2009, 04:41 PM
layson's Avatar
Quoted: 84 Post(s)
I didn't... but I don't think it would hurt anything to use it...
I just got it good and tight.. used the cheater method with another wrench...
Quote of the Day:
layson is offline
post #7 of 8 Old 04-02-2009, 05:54 PM
CSIPSD's Avatar
No lock tight, get them good and tight and be done. There a ***** to get off if you ever have to even without locktight.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #8 of 8 Old 04-02-2009, 06:21 PM Thread Starter
GreenF350's Avatar
Right on....all set then I think. Everyone keep an eye out for a post from me this weekend asking for help...hahaha. Either way I will let everyone know how it went and what the results are. I'm hoping one long day will get bellowed up pipes, turbo, pedistal, and maybe the CCV mod done. I guess we will see.
-Aaron
