which boost fooler - Ford Powerstroke Diesel Forum
Old 04-01-2009, 02:22 PM
Send a message via MSN to Jesse.James
which boost fooler
Well i decided its time to get a boost fooler, but which one? I saw one from SP that plugged into the wiring harness and i see some from ITP that have a guage you can dial in, so which kind is the best?
Old 04-01-2009, 02:44 PM
I did the DIY works great. It is a air presure regulator you gan buy at any hardware. as long as it regulates down to below 20psi.
Old 04-01-2009, 03:30 PM
i bought the SP one that your talking about it works fine but it is the same thing as a 4.7v zener diode that you can get for a $1 if you have a electronics store near you or get one from ebay or different places and it just crimps inbetween two wires from the map sensor theres threads about it on here. But buy the time I seen these threads I had already ordered mine but its not to late for you. Noone has had a problem with them that I know of. The SP diesel one is the diode just prettier with a harness with it.
Old 04-01-2009, 03:32 PM
maybe ill just do that
Old 04-01-2009, 03:36 PM
i think its the best choice I just wish I would have seen the threads before I bought mine would have saved about $49. i could fined the threads for you if you cant and post the link on here. The diode just limits the signal to the computer to 4.7v which is under the limit so the computer thinks your at normal boost levels when your not
Old 04-01-2009, 03:41 PM
just incase you havent found it here it is 4.7V Zener Diode Boost Fooler
Old 04-01-2009, 03:49 PM
ya. the 4.7 kicks butt. you dont have to splice either. just push into place inside the plug.
Old 04-01-2009, 04:10 PM
Just go to Home Depot and pick one up... Then set it with your air compressor.
Old 04-01-2009, 05:42 PM
thanks man
