Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 01-15-2007, 12:54 PM
blugreenformula blugreenformula is offline
Upgraded injectors??????????
Well as I thought I need to by 3 new injectors for my '01. Is there anyone who makes performance injectors for this truck? At 435.00 a piece I might as well upgrade the whole set since it will only be a few hundred more. Thanks in advance!
Old 01-15-2007, 12:58 PM
stump0331 stump0331 is online now
SNAFU Stump
Tournaments Won: 1
i havent got to that point yet, definately hit up our vendors for great pricing
Old 01-15-2007, 01:31 PM
720Deere 720Deere is offline
You may want to do a little web surfing with Alliant Injectors as your target. These are new not rebuilt injectors made by a company that manufacturers injectors for Caterpillar. I know for a fact that you can buy a complete set of 8 for a little over $1800! That includes shipping and handling.
Also as Stumpy stated, we have plenty of supporting vendors here that should be able to hook you up. $435 each for standard injectors is a ripoff. I think the Ford dealers only charge about $300 each.
Old 01-15-2007, 05:04 PM
lukecline
Tournaments Won: 1
Posts: n/a
check out Beans Diesel Performance for some kickazz injectors
Old 01-15-2007, 05:09 PM
dirt mover dirt mover is offline
also check out dynamite diesel performance, they gotem
Old 01-15-2007, 05:24 PM
Maintain Maintain is offline
sexy
Send a message via AIM to Maintain
You can usually get them (Alliant) for around $200 each IIRC if you don't go to the Ford parts counter otherwise you'll be looking at 350-400 bucks. *after core charge
You may want to go this route, and only replace the 3 bad injectors.
Check with the vendors, they should be able to set you up if you want to replace all 8...
Surprising you have 3 inj go bad on an 01 - might want to check into possible reasons for that before you go handing out your hard earned money!!!!!
Old 01-15-2007, 06:09 PM
I took it to Ford today, they didnt have a scan too that showed which injectors werent working properly. They had a breakout box to kill each injector individually, the 3 the tech narrowed it down to cyl's 1, 5, and 7. He said to first change the oil again, it looked bad. ( I changed it 2 nights ago.) So could bad oil could cause the injectors to perform poorly. The previous owner only ran Moble1, I switched it to Rotella. does this make any sence???
Old 01-15-2007, 07:25 PM
Albie30 Albie30 is offline
Send a message via AIM to Albie30 Send a message via Yahoo to Albie30
Yes that does makes sense oil pressure runs the injectors the oil needs to be changed reguarly because of this .Make sure you check the the hpop I had a mechanic tell me I had 3 injectors bad Turns out they were all fine and my hpop was bad spent 2 grand for nothing .I bought mine from Beads Diesel Performance They were great to deal with Spent alot of time on the phone with them
Old 01-15-2007, 08:10 PM
another thing to try is a product lucas makes. I have changed the fuel filter and filled it with this stuff and i fixed it believe it or not. Know more than it costs its worth a try. The injectors were so bad it barely ran and after we did that it was running smooth.
Old 01-16-2007, 10:36 AM
jbawilliams jbawilliams is offline
Dont rule out injectors from IH. I had Ford ones priced at $300 - $350 for my 96 that I had, and I got one from local big truck repair place for $180.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
