EBPV Questions - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-26-2009, 04:27 AM Thread Starter
roccodart440's Avatar
EBPV Questions
What is the purpose and advantage of gutting the turbo pedistal and plugging the EBPV?
I just watched this video. http://www.powerstroke.org/forum/7-3...-pedistal.html
Thanks
2005 350 SDSC 4x4 Auto 6.0h no
Mods
turbo back exhaust, EGR delete, GPS, DVD, MP3
Privacy glass
For now.............................
roccodart440 is offline
post #2 of 13 Old 03-26-2009, 05:36 AM
Powerstroke Techie
alabamafrog's Avatar
Reasons I did mine were because it was leaking oil and my EBP sensor tube was rotted out and it was acting up. I did some tests and my warm-up times were not noticeable affected with it disabled and I don’t like unnecessary mechanisms that can fail. I used a pipe tap to tap out the treads and a pipe plug to plug the hole. I also removed the flapper from inside the Down pipe flange and put pipe plugs in the flapper pivot holes.
Here are pics of when I did mine;
Powerstroke Turbo pictures by alabamafrog - Photobucket
“Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one” (T Paine)
Government cannot give anyone anything without stealing it from someone else. (A Frog)
alabamafrog is offline
post #3 of 13 Old 03-26-2009, 06:36 AM Thread Starter
What function does it perform on a stock truck?
Once you go with a performance exhaust there can't be much back pressure.
Mods
Privacy glass
post #4 of 13 Old 03-26-2009, 07:21 AM
Powerstroke Techie
It is supposed to be a cold weather warm up aid. The way it is supposed to work is when the truck is cold it closes the butterfly valve and pretty much blocks off the exhaust kinda like outing a potato in the tail pipe. When it is on you should be able to hear it and the truck should have almost no power, and if everything is working right it should blow open if you get on the throttle hard enough. After the engine is warm enough it should open and remain open until the engine cools too much.
IF (notice ‘if’ is capitalized) it were to stay closed it could cause extremely high egt and make bad things happen.
Stock exhaust or performance exhaust makes no difference to this device, it is the part that you hook the exhaust to so it is there on both setups.
post #5 of 13 Old 03-26-2009, 08:13 AM Thread Starter
Hmmm, I wonder if mine is not working right. I don't hear anything funny when it is cold and it pumps exhaust right out fast. I have on a few occasions taken off when it was cold out and the truck was cold and it would barely go.tHen all of a sudden it was ok.
Mods
Privacy glass
post #6 of 13 Old 03-27-2009, 03:09 PM
so what do you have to do with the sensor after you gut the pedistal and remove the ebv.
2001 F-250 4x4
Marty's Fuel
Swamp's 250/200's
Swamp's Tunes
PDR Super GTP Turbo
BTS
PMR'S
Soon to come - SRP 1.1
njjeep is offline
post #7 of 13 Old 03-27-2009, 03:17 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
You can always rig up an exhaust brake with the EBPV
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #8 of 13 Old 03-27-2009, 03:18 PM
2001 F-250 4x4
Marty's Fuel
Swamp's 250/200's
Swamp's Tunes
PDR Super GTP Turbo
BTS
PMR'S
njjeep is offline
post #9 of 13 Old 03-27-2009, 03:22 PM
Quoted: 6 Post(s)
I dont know. Havent gutted one myself!
post #10 of 13 Old 03-27-2009, 03:32 PM
layson's Avatar
Quoted: 83 Post(s)
unplug it...
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
