Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 01-07-2007, 08:00 AM
SDNate SDNate is offline
need boost gauge install help
Should I t-off the MAP line or drill and tap? Not a big fan of pipe tap at all especaly in an aluminum turbo housing. Any drawbacks to t-ing off the Map line?
Old 01-07-2007, 09:45 AM
strokermann strokermann is offline
if you are a little scared of tapping the aluminum the map line would be your best bet. i have mine that way. but i have heard you get a inaccurate reading. just get as close as you can to the y-pipe. its quick and simple on the map. and plus you don't have to worry about taking off y-pipe. hope this helps.
Old 01-07-2007, 09:54 AM
Maintain Maintain is offline
sexy
Send a message via AIM to Maintain
You have another choice. You can buy a bolt that will fit in the place of the AIH. Drill and tap that bolt so it will accept a boost fitting. If you want more info on this, pm me.
Old 01-07-2007, 10:00 AM
i forgot about that. i didn't have that otion. sorry for missing that
Old 01-07-2007, 10:05 AM
luckydog luckydog is offline
OK, I'll be the dummy for today. What's the AIH?
Old 01-07-2007, 10:38 AM
steph38 steph38 is offline
AIH= air intake heater chek out sponsors they already have with fitting so u'll only have to plug the hose from your gauge.
Hope could help
Old 01-07-2007, 01:04 PM
Postal Postal is offline
Which sponors have this AIR fitting steph38?
Thanks
Old 01-07-2007, 01:34 PM
Lord Tauk Lord Tauk is offline
Send a message via ICQ to Lord Tauk Send a message via AIM to Lord Tauk
I like the MAP line idea, several vendors offer a "tee" that in the middle has a bleeder so the motor never defuels but still gets maximum boost to whatever your mods are making, plus 1/8 NPT ports to screw in your gauge's hose.
I don't see how it could be less accurate than AIH delete boost fitting, or tapping in anywhere else where you would get boost, it'll read 10PSI all over regardless of where you tap in unless you have a leak somewhere.
Old 01-07-2007, 06:25 PM
MartyB MartyB is offline
Teeing into the map line is very easy, and inexpensive. It's also just as accurate as anywhere else. Adding a pressure regulator inline here will also help avoid the SES light due to overboost.
Old 01-07-2007, 07:51 PM
Thanks
look for Dfuser site Bill will help u
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
