7.3 SMOKE SWITCH !!! - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 50 Old 02-21-2009, 11:35 AM Thread Starter
Exclamation 7.3 SMOKE SWITCH !!!
Did anybody ever heard or try this ? or just have any ways to make a 7.3 blow so black smoke ?
The smoke switch tricks your pcm into thinking you have full boost so it pumps in fuel. Just take your 5volt reference wire to your map and run a wire taped into that into your cap to one side of a switch. then take and splice a wire into your return (signal) wire on your map and run it to the other side of the switch in the cab. when the switch is on it will send a full 5v to your pcm and make it think you have full boost so it will dump in fuel. its really easy and it doesnt hurt anything if you do it right
cummins eater is offline
post #2 of 50 Old 02-21-2009, 02:18 PM
Tony V's Avatar
I'd do something wrong most likely
2000 F-250 216k- smoke much?
Facebook: Anthony VanCamp
Add me if you'd like
Tony V is offline
post #3 of 50 Old 02-21-2009, 02:30 PM
Diagram maybe?
nvrdun is offline
post #4 of 50 Old 02-21-2009, 02:33 PM
bravo-man's Avatar
i second that!!!!
2003 7.3 PSD,PHP fuel-sipper,40,120,140,no-start,diy intake,John Wood VB / GTP 38r at 31-32psi,foil delete,4" ex open,banks gages,banks TC broken,banks power elbow,zoodad,BD wastgate
Check out my gallery
08 6.4LARIAT 4x4 Dually,DPF/CAT DELETE, SPARTAN 210 Now 275 TUNED,AFE stage 2
http://www.dpfdeletekits.com/
bravo-man is offline
post #5 of 50 Old 02-21-2009, 06:04 PM
Send a message via Skype™ to Powerstroke 81
Tell us more!!!
8inch lift 40/15.50/22 tires.
5inch stacks,foil delete,CCV MOD,5.6K MOD,Superchips Flashpaq.
Powerstroke 81 is offline
post #6 of 50 Old 02-21-2009, 06:06 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
We will need crayons, lots of them. Maybe some construction paper too!
SleepingDemon87 likes this.
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #7 of 50 Old 02-21-2009, 06:08 PM
pwrstrkr's Avatar
lets see a diagram and a vid??
2005 6.0 King Ranch | Pretty stock...
2007 Dodge 5.9 cummins 6spd w/ some mods....526hp/1010tq SOLD
2000 7.3 ccsb SOLD
pwrstrkr is offline
post #8 of 50 Old 02-21-2009, 06:21 PM
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78 Send a message via Yahoo to Dieselfever78
If you send a full 5v to the map signal in the PCM then it will throw a CEL and defuel because it thinks your overboosting. Plus the usable range of the map sensor is ~.5v to ~4.5v, the upper and lower .5v is a buffer so you can detects shorts(i.e. short to ground would be less than .5v and Ref. Voltage short would be 5v)
Why would people be buying and installing boost foolers if they could show the MAP sensor full voltage without defueling?
And it surely doesn't work on OBS trucks because the MAP sensor works on Hz(Hertz) frequency instead of Analog voltage.
-Michael
1997 F350: Regular cab, XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Tow/Street Truck
Swamps 200's, Modded H2E, HMR Street Puller, Fuel system, Swamps Programs
2001 VW Golf Four Door GLS, 1.9L TDi, 5 speed - Almost makes fuel
Sold: 2000 F350: Crew Cab, 7.3L PSD, 6 speed, Dually - Pulling truck
Dieselfever78 is offline
post #9 of 50 Old 02-21-2009, 06:26 PM
handymanbrandon's Avatar
-Michael
I'm glad you spoke up. Something didn't seem right but I am still learning about this stuff so I wasnt sure. From what I have heard, when you reach max boost, the computer says 'no more' and cuts your fuel.
02 F-250
7.3 6 speed manual
6637
Zoodad
4" from the turbo
Cat delete
Foil delete
Clearance lights
Much more on the way...
handymanbrandon is offline
post #10 of 50 Old 02-21-2009, 10:03 PM Thread Starter
So there is probably no way to make a 7.3 smoke other than having a chip in smoke mod lol !
