Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 12-31-2006, 07:20 AM
jimscordato jimscordato is offline
Angry Down pipe install help
I'm tring to install a MBRP 4" turbo back system on my 2002 F250 and cannot get the down pipe through the opening. MBRP is closed and I see, on their web site that some other folks have had a problem but the install instructions don't mention any help for this. I tried for 3 hours with no luck. I also see that on the 6.0 that it's harder with the 6 speed, I have the 6 speed but being a 2002 it's a 7.3 Any help or advice would be appriciated.
Old 12-31-2006, 08:00 AM
pipelayerjdh pipelayerjdh is offline
MINI-MOD
I wish I could help, but I've only done it on a few OBS's. I havn't tried it on a SD, yet. I have found that jacking up the left side of the motor helped with mine. Don't know if it will help or not.
Old 12-31-2006, 08:36 AM
sea71 sea71 is offline
It's just me
I have an 02 also. I used mbrp and the pipe went in with no problem. Thats not what you wanted to hear, I know, but I want to help in some way. I did mine in an hour with the help of my father in law. He held the down pipe up so I could attach the clamp. I know you have to turn the bend in the pipe so it will "work" into the space, but once in mine fit like a glove with room to spare.
Old 12-31-2006, 08:49 AM
I'm going to go give it another try. Will try jacking up the side to try to increase the clearence. I tried putting it in with the tail facing forward but there isn't enough clearance for it to turn once there, it hits the block.
Old 12-31-2006, 09:03 AM
Ditty Ditty is offline
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
Just like Sea71 said, you have to WORK that sucker in there. Mine was a total PITA! I thought I was doing something wrong for about 2 hrs and was ticked b/c I was unable to reverse my install b/c I had cut the stock exhaust in 3 places. Just keep at it and twist the poo outta that DP. You'll get it in there!!!!
Old 12-31-2006, 09:33 AM
Maintain Maintain is offline
sexy
Send a message via AIM to Maintain
x3 on Shane's, and Ditty's comment - twist it!
Old 12-31-2006, 11:08 AM
I finally got the down pipe through I jacked up the passenger side of the truck and it made it worse so I jacked up the drivers side and it almost made it so with a little excessive force it made it. Thanks for all the help.
Old 12-31-2006, 05:05 PM
99 7.3 99 7.3 is offline
good deal, ya it's a pain in the @$$. did u get it hooked up to the turbo yet? now that was my problem. i think i called it the girl that works on the corner many times w/ an adjective to describe her. no wait, i'm sure of it!!!
Old 12-31-2006, 05:10 PM
Logan Logan is offline
The Fat Mod
LMAO
Old 01-01-2007, 06:35 PM
I had to read that like 5 times to get it. I was thinking, "Why TF is he talking about a working girl in a DownPipe thread?" then I got it.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
