Ts 6 Chip Question. . - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-05-2014, 03:59 PM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
Hi guys...
I got an opportunity to get a second ts 6 chip but it came of a 2002 7.3 auto....would it be compatible with my 2001 7.3 auto or are the pcm different? .....Supposedly it only has 4 tunes on it since it was custom tuned...Any thoughts or suggestions?
Thanks!
2005 F350 Harley Davidson Edition CCSB SOLD!!!
Icon Vehicle Dynamics 4.5" stage 4 lift, 37x13.5R20 Toyo Open Country M/T, 20x10 Fuel Throttle wheels, ARP headstuds, EGR delete, MBRP 5" powdercoated turbo back exhaust, wicked wheel, Blue spring mod, Mishimoto Radiator, oil cooler, stand tubes and dummy plugs, Sinister Diesel coolant filter, 6.4 banjo, Air Raid air filter, SCT X4 tuner with tunes from Innovative Diesel, EGT, HPOP, fuel pressure A-pillar gauge pod
Msp079 is offline
post #2 of 10 Old 08-05-2014, 04:46 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
it should work.
hopefully one of the tuners will stop in
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is online now
post #3 of 10 Old 08-08-2014, 06:20 PM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
Thanks Blue...
Anyone else have an opinion before I grab it this Sunday?
Msp079 is offline
post #4 of 10 Old 08-08-2014, 06:45 PM
sbluke55's Avatar
Quoted: 551 Post(s)
Garage
I would get the PCM code from both pcm's and post them up to make sure they are comparable.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #5 of 10 Old 08-08-2014, 06:50 PM
i thought some of the computers were different, atleast when i ordered mine from PHP they wanted to know the numbers/letters on PCM
1fastblackz is offline
post #6 of 10 Old 08-08-2014, 06:51 PM
CSIPSD's Avatar
It will not work... Two completely different PCM's. Not codes, but physical PCM families
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #7 of 10 Old 08-08-2014, 11:56 PM
What he said...a while back I sent a chip off for a reburn and it came back with the wrong pcm code. The truck would crank up and run but would shut off anytime you changed tunes going down the road.....not fun to say the least.
2003 F250 7.3, PHP Phoenix, 4"exaust, Banks Big Head, WW2, Tymar, 4" lift with 35's
Montgomery P-Stroke is offline
post #8 of 10 Old 08-09-2014, 05:29 AM
Quoted: 782 Post(s)
That's the huge advantage of the Hydra chip. Not having to send it out for a reburn.
Corey@CNCFAB is offline
post #9 of 10 Old 08-10-2014, 06:15 PM Thread Starter
Msp079's Avatar
Quoted: 52 Post(s)
If I get the chip could you re burn everything Corey with power stuck tunes?
If I gave you my pcm for my truck would that be enough to re burn the chip so it functions properly without issue?
Msp079 is offline
post #10 of 10 Old 08-10-2014, 06:26 PM
Quoted: 782 Post(s)
Definitely.
