turbo boost - Ford Powerstroke Diesel Forum
post #1 of 32 Old 08-05-2014, 01:37 PM Thread Starter
GOODOLEBOYZ250's Avatar
turbo boost
Should I not see more boost out of my truck. Pulling roughly 7000 pounds going 55 up.hills here in sc I might see 8 or 9 pounds of boost on my tow/economy setting.. so I took a couple pics empty 1st is economy setting 2 nd is street. Also whats the procedre to do a boost leak test. I got the cap and nozzle, how do I plug off the ccv
ID:	320417   Click image for larger version
2001 f250 7.3 auto... sniper 175, 80 percent injectors(for now)., garrett super 100, built trans, diamond eye straight pipe 4 inch , isspro ev2..gearhead tunes..bellowed pipes..ebpv delete..6637 filter..plus more to come..
GOODOLEBOYZ250 is offline
post #2 of 32 Old 08-05-2014, 02:21 PM
Vannnce's Avatar
Quoted: 13 Post(s)
yeah you should. truck in sig, On a merge on to the freeway kind of acceleration, i am at 12-20, WOT i can hit 32. cruising at 70 around 4 and cruising at 55 about 1. I can hit 32PSI empty or loaded in any of my setting (tow, economy, race)
Your max boost will vary based on the tune and the truck. but even stock you should see more than 9 psi
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #3 of 32 Old 08-05-2014, 02:38 PM Thread Starter
My Max at 3000 rpms is about 20 as shown in the pic on street setting
post #4 of 32 Old 08-05-2014, 04:48 PM
blue99stroker's Avatar
Quoted: 272 Post(s)
yikes with that size injectors on a stock turbo should be between 30-40 psi
do you actually have 175/80's? who knows with sniper
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 32 Old 08-05-2014, 05:15 PM Thread Starter
I agree that's why I was asking. Figured it was a leak somewhere or the injectors
post #6 of 32 Old 08-05-2014, 10:24 PM
heykw's Avatar
You have some type of leak. Check your up pipes also.
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #7 of 32 Old 08-06-2014, 12:25 PM Thread Starter
Well found one leak on the driver side boot in the valley. Fixed it and up to 23 at 3000 rpms on econmy. Still hear more leaks tho. Should the system hold.pressure.or.will it leak out naturally
post #8 of 32 Old 08-06-2014, 12:55 PM
sbluke55's Avatar
Quoted: 575 Post(s)
Garage
Use a little bit of dawn with some water in a squirt bottle and pressure up they system and start spraying connections. Also spray the end caps on the intercooler. Then check your up pipes for soot
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #9 of 32 Old 08-06-2014, 05:01 PM Thread Starter
The up pipes leaking will cause pressure loss
post #10 of 32 Old 08-06-2014, 05:40 PM
Quoted: 28 Post(s)
Boost leak test only checks the intake side of the boost system so up pipes aren't checked with boost leak test but they will cause a drop in boost and higher egts. How much really depends on how bad the leak is.
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
