E 99 7.3 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-05-2014, 09:55 AM Thread Starter
E 99 7.3
what is the best turbo to add if i keep stock injectors? garret gtp38r is one i am thinkin of
madeline is offline
post #2 of 5 Old 08-05-2014, 11:32 AM
Cllake's Avatar
You will need to update the crossover, intake and up pipes to the late 99-02 parts to run that turbo. I believe the Beans D66 is a better bolt on turbo for the E99. Do some research, there is alot to be learned from 20 mins of google.
E1999 Crewcab Short bed SW: 06 Front axle swap with ICON leveling kit and PMF 3-link. N-Fab side steps. ICON rear shocks. 06 Front end with 10 rear end. PHP chip, straight piped with AEM intake. Rigid lights. 35 Hercules Trail Diggers on 20x10 Procomp wheels.
Cllake is offline
post #3 of 5 Old 08-05-2014, 01:25 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
a d66 would be perfect and its the only drop in available for an e99.
like Op said you need intake manifold, up pipes, intake plenums, pedestal to make the later style setup work.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 5 Old 08-05-2014, 02:50 PM
Go with a D66 from beans with a billet wheel and 1.00 exhaust outlet and you'll be very happy with stock injectors. Should hit mid 20s but faster spool up than stock and with bigger injectors (up to stage 2s) you can hit 40 psi with this turbo set up. This is my plan just need the money! But I hope to have 180/30 when I do it.
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
post #5 of 5 Old 08-09-2014, 11:03 AM
Quoted: 768 Post(s)
There are a few who make the D66 version. Beans, Industrial Injection, BD-diesel, Barder, and a few others. I carry the Industrial and BD version if your interested.
Or you can send your turbo in and have it machined into a D66 and buy the bigger 66mm wheel.
Corey@CNCFAB is online now
