ZF6 Clutches - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-01-2014, 04:04 AM Thread Starter
diesel22s's Avatar
ZF6 Clutches
Looking at getting a Southbend clutch for my truck, and the 1944-60K seems to be the way to go so I can get rid of the factory flywheel. Has anybody ever used the 1939-DF, its the semi style clutch that will work with the factory flywheel. Could save a couple bucks but not sure if that is a good move.
E99 F-250, 4 inch lift, 35 inch tires, dual 4 inch exhaust, DIY 6637 intake
diesel22s is offline
post #2 of 11 Old 08-01-2014, 05:40 AM
What are you planning on throwing at the truck? What's your plans for the truck; towing, Racing, DD, ect. Depending on your plans for the truck, the clutch you choose will be different. When you replace the clutch and not the flywheel, you need to get your flywheel resurfaced. If not, you can glaze over your new clutch and there goes a chunk of money. Also if you've never replaced the clutch fork, go with one from Ford. The old design was prone to break and it saves you having to drop the trans again if it happens.
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
post #3 of 11 Old 08-01-2014, 05:57 AM
sbluke55's Avatar
Quoted: 548 Post(s)
Garage
What he said^^^^^
Also what I recommend is give them a call and talk to a representative. Tell them your plans, hp goal, and how your are going to use it. Also be realistic with your hp. A stock truck is around 250hp. You will be hard pressed to get above 400 hp. The previous owner of my truck put in a race clutch and thought it had all this hp and it makes it very hard to drive in every day operations.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 11 Old 08-01-2014, 08:01 AM
Quoted: 27 Post(s)
Originally Posted by sbluke55 View Post
What he said^^^^^
Agreed. I replaced my clutch with a 450 HP rated one. I plan to get to that tho in the next 6 months.
But as of now it shifts kinda hard unless im getting on it or have a good load behind me, then it shifts like butter.
And just like previously said, replace your clutch fork! I learned the hard way.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #5 of 11 Old 08-01-2014, 12:19 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I have the higher rated 1939... do not like it at all. Spend the money for the the 1944
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #6 of 11 Old 08-01-2014, 12:28 PM
schlutzer's Avatar
Quoted: 18 Post(s)
There is also no benefit to getting rid of a factory flywheel on these trucks. Thats with the OBS
post #7 of 11 Old 08-01-2014, 02:06 PM
Shadowfax's Avatar
Quoted: 13 Post(s)
I used the 1944-6ok when I did my swap. I love the clutch. My truck is my dd, I've had the clutch in for a year and a half. Pedal effort is exactly what I would expect and want for the truck. I've only had the clutch get hot enough to smell one time and that was backing a heavily loaded trailer into a super steep up hill driveway at a real sharp angle. I didn't think to put it into 4lo until I smelled it.
I do have plans for more hp than the clutch is rated for but I guess I'll cross that bridge when I come to it, who knows how long that will be. In the mean time the clutch is perfect for my application. I would recommend it for a person with basic stuff.
2015 f350 lariat
2003 Jetta TDI 5spd
Shadowfax is offline
post #8 of 11 Old 08-01-2014, 02:36 PM
Quoted: 780 Post(s)
I carry South Bend if your interested.
Corey@CNCFAB is offline
post #9 of 11 Old 08-01-2014, 02:56 PM
Quoted: 27 Post(s)
No but the benefit can be had when you dont have to wait to get your old one resurfaced. I need my truck every day so ordering the complete kit was great. One night job and good to go.
post #10 of 11 Old 08-01-2014, 05:38 PM Thread Starter
diesel22s's Avatar
I am getting ready to do a big overhaul with the truck, so I was planning on putting Stage 1 injectors and tuner when I have the cab off. Right now the truck just has 4 inch exhaust and a DIY intake. I think the 1944 will be the way to go because then everything will be new including the fork and flywheel. I believe its first clutch above stock horsepower, so shouldn't be a problem since I'm not trying to build a race truck.
