boost sensor help - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-31-2014, 12:21 PM Thread Starter
GOODOLEBOYZ250's Avatar
boost sensor help
Need some ideas on my best option for securing my boost sensor. Was really nervous about the egt sensor.but it.went smooth. Thought the boost would just be the map line t like ive done before but.it was the drill and tap sensor. Figuered it would be more accuarte that way so I gone ahead and tried it but I drilled little to close to the clamp lip and its hitting before it gets snug. Was thing of shaving the lip down in that one spot but wanted some more ideas.
ID:	318409   Click image for larger version
2001 f250 7.3 auto... sniper 175, 80 percent injectors(for now)., garrett super 100, built trans, diamond eye straight pipe 4 inch , isspro ev2..gearhead tunes..bellowed pipes..ebpv delete..6637 filter..plus more to come..
GOODOLEBOYZ250 is offline
post #2 of 6 Old 07-31-2014, 01:03 PM
sbluke55's Avatar
Quoted: 526 Post(s)
Garage
If it's hitting the casting lip on the left on the second picture grind it off. It does nothing. It's just left over material from the casting process.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 6 Old 07-31-2014, 01:10 PM
dannanw's Avatar
Quoted: 64 Post(s)
Garage
grind away....
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #4 of 6 Old 07-31-2014, 01:50 PM Thread Starter
Ok any other tips. Teflon, loctite etc.?
post #5 of 6 Old 07-31-2014, 01:52 PM
sbluke55's Avatar
Quoted: 526 Post(s)
Garage
3-4 wraps of Teflon should do it. Keep the Teflon on the threads, you don't want any hanging over. Also make sure it goes the right way or it will just wad up and not do anything.
01 f-250, Standard
sbluke55 is offline
post #6 of 6 Old 07-31-2014, 02:19 PM Thread Starter
Ok thanks for the help...
