Turbo rebuild - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-31-2014, 10:26 AM Thread Starter
Turbo rebuild
So I'm new to all of this, I have a 2000 f-450 tow truck 7.3 motor. Had a serious oil leak from my turbo. Took it to my mechanic they took the turbo out and found that it was leaking from this shaft the seal was gone. So now it's time to put the turbo back. And his saying if I can get the parts I have no idea what I'm buying and it would actually save me if I brought it he said. His saying my way of learning about what I have. Okay my problem is this who sells the gaskets kit or what I need to rebuild and put everything back. I have no idea what I'm looking for. Being from Hawaii (Oahu) it makes it hard to get the right parts. I could go to my local ford dealer but I'm sure they would rape me like they do with everything else I brought. Also upgrades while the turbo is out any suggestions as to what I should get and who from. Better if your a dealer I need someone I can work with. Mahalo RnC Towing
Pictures is the turbo out second picture is where the oil was leaking from the port his saying I need a gasket and o-ring.
RNC TOW is offline
post #2 of 7 Old 07-31-2014, 03:34 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
barder turbo has a great upgrade rebuild kit for less than 100 bucks.
might want to get a new billet compressor wheel while its out.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
The Following User Says Thank You to blue99stroker For This Useful Post:
RNC TOW (08-15-2014)
post #3 of 7 Old 07-31-2014, 09:25 PM
StrokinAlaska's Avatar
Billet her up for sure, you'll be happy. Dieselsite ww2 was 229 if I remember correctly. Riffraff is great also
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
The Following User Says Thank You to StrokinAlaska For This Useful Post:
post #4 of 7 Old 08-01-2014, 05:19 AM
I just rebuilt my turbo using a billet wheel and bushing kit from Riff Raff. Fairly easy to do, Riff Raff has a great web page that allows you to see step by step instructions. I also replaced my stock up pipes with Dorman, as they were also leaking ( truck has 250K miles on it). Runs great, no problems with oil leaks now.
redmanmbz is offline
The Following User Says Thank You to redmanmbz For This Useful Post:
post #5 of 7 Old 08-01-2014, 06:59 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Go ahead and delete the ebpv since it's never cold there, and get a deleted pedistal (more of an oil leak prevention)
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
The Following User Says Thank You to 351fifty For This Useful Post:
post #6 of 7 Old 08-01-2014, 12:00 PM
03ranger30's Avatar
How was doing the up pipes? I finally have a day coming up that I can do mine and was just looking for any advice on it.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #7 of 7 Old 08-02-2014, 07:43 AM
joebuck's Avatar
Quoted: 35 Post(s)
Just did mine not long ago,WOW what a pita that can be,but makes a huge difference,before WOT I would see 10psi max,now I can see 20-22psi on 100hp tune nothing crazy! It takes some patience and a TON of PB bolt breaker,start spraying it a few days earlier so it can soak in,just getting at everything is a big task so take your time and follow the write ups on here to do it made it fairly simple once knowing what I was getting at!
2001 F250 XLT
EX cab,LB
5" side exit exhaust
AFE stage 2 intake
Banks 1.0 exh. housing
Riff Raff billet wheel
PHP tuned
6" lift on 37's
joebuck is offline
