Turbo rebuild - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-31-2014, 09:20 AM Thread Starter
Turbo rebuild
So I'm new to all of this, I have a 2000 f-450 tow truck 7.3 motor. Had a serious oil leak from my turbo. Took it to my mechanic they took the turbo out and found that it was leaking from this shaft the seal was gone. So now it's time to put the turbo back. And his saying if I can get the parts I have no idea what I'm buying and it would actually save me if I brought it he said. His saying my way of learning about what I have. Okay my problem is this who sells the gaskets kit or what I need to rebuild and put everything back. I have no idea what I'm looking for. Being from Hawaii (Oahu) it makes it hard to get the right parts. I could go to my local ford dealer but I'm sure they would rape me like they do with everything else I brought. Also upgrades while the turbo is out any suggestions as to what I should get and who from. Better if your a dealer I need someone I can work with. Mahalo RnC Towing
Pictures is the turbo out first picture is where the oil was leaking from the port his saying I need a gasket and o-ring.
RNC TOW is offline
post #2 of 11 Old 07-31-2014, 09:30 AM
sbluke55's Avatar
Quoted: 588 Post(s)
Garage
Turbo rebuild
I would get a new billet compressor wheel from riff raff diesel and a 360* thrust washer rebuild kit from barder turbo. Total for all parts would be $300ish.
Also the wheel will help eliminate turbo surge while towing. Surge can cause turbo damage.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
RNC TOW (07-31-2014)
post #3 of 11 Old 07-31-2014, 09:37 AM
sbluke55's Avatar
Quoted: 588 Post(s)
Garage
You can also do a delete pedestal and remove the ebpv on the turbo outlet. The valve in the pedestal has a tendency to leak. It's not necessary tho.
01 f-250, Standard
sbluke55 is offline
post #4 of 11 Old 07-31-2014, 10:29 AM Thread Starter
So the piece I'm showing is the pedestal for the turbo?Turbo rebuild-image.jpg
RNC TOW is offline
post #5 of 11 Old 07-31-2014, 10:58 AM
sbluke55's Avatar
Quoted: 588 Post(s)
Garage
That is the pedestal. This is stock Attachment 318385
This is the deleted one. Attachment 318393
It leaks where the rod comes out.
01 f-250, Standard
sbluke55 is offline
RNC TOW (08-15-2014)
post #6 of 11 Old 07-31-2014, 11:01 AM Thread Starter
So what is it that I'm showing ? His saying it was leaking from here! Hope the picture shows upTurbo rebuild-image.jpg
And this is where I need the gasket and o-ring for!
RNC TOW is offline
post #7 of 11 Old 07-31-2014, 11:02 AM
yes thats the pedestal,
go here
DieselOrings
he has a help page, showing how to rebuild a turbo,
he sells the rebuild kits also,
I just posted pictures of my rebuild,here,
Turbo Rebuild RiffRaff Billet and hight temp paint
and another place to look that shows it very nice is here
Barder's 360 bearing rebuild,XDP billet,Applied Performance - Diesel Forum - TheDieselStop.com
RiffRaff is also another great place to buy the parts also,
i got most there, but my pedestal i got from the "o" ring,
its not hard, just take your time,
if your mechanically inclined, its actually fun,
except for that back down pipe clamp, its a bear,
you can do it yourself and save ALOT OF MONEY,
if you do a new wheel GET IT BALANCED to the shaft,,thats MY opinion,
others say you don't have to,,
hope this helps some
john
2000 F-250 XLT
6spd, Short,bed,
175,000 miles, (when I bought it, 134,000)
6637 DIY Air Filter
EV2 Pyro,Boost, gauges
Muffler-Delete (came that way)
Turbo Rebuild with Billet RiffRaff Wheel,(Balanced)
Turbo and Spider, Painted Red
Intercooler-Tubes, Painted,RED
Non-EBPV Pedestal, Painted,RED
EBPV valve delete Mod
DRK Blue CPS, "Black" one in the Glovebox
24ft alpenlite,sliding hitch, for those days when civilization isnt so civilized
2000Ford7.3 is offline
The Following User Says Thank You to 2000Ford7.3 For This Useful Post:
post #8 of 11 Old 07-31-2014, 11:04 AM
rebuild kit for the pedestal,
make shire its your year
EBPV Pedestal Rebuild Kit 99-03 - Riffraff Diesel Performance
i chose to buy a NON-EBPV pedestal,
2000 F-250 XLT
6spd, Short,bed,
6637 DIY Air Filter
post #9 of 11 Old 07-31-2014, 11:07 AM
sbluke55's Avatar
Quoted: 588 Post(s)
Garage
Here is the delete pedestal and it's only $25 more. http://www.riffraffdiesel.com/garret...estal-99-5-03/
I'd delete it so it won't happen again.
01 f-250, Standard
sbluke55 is offline
post #10 of 11 Old 07-31-2014, 11:19 AM
^ What sbluke55 said,
thats why i did that almost the same price and ill never have the leak again
but you'll have to delete the flapper valve in your turbo also, easy to do,
2000 F-250 XLT
6spd, Short,bed,
6637 DIY Air Filter
