Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 12-25-2006, 08:23 PM
Chaffeediesel Chaffeediesel is offline
450 HP out of 01 Stoker
I am looking for input from all you super intelligent diesel nuts on how to get 450 hp out of my 01 stroker i would like to compile all information and see what combinations worked well for others and not others thanks
Old 12-25-2006, 08:27 PM
twildman twildman is offline
First thing you need to do is find out whether or not you have forged rods. If you do have forged, you will need to get an open intake, 4 inch exhaust, set of 230ish cc hybrid injectors, custom tuned chip, wicked wheel or ATS housing for the turbo, make sure you have a regulator in front of the map sensor, and you will be at least that.
If you have pmr's get a set of stage II injectors, wicked wheel, custom tuned chip to keep it at 400 or you will likely install windows 07 in your block.
Guages are a given of course.
Old 12-25-2006, 08:44 PM
Logan Logan is offline
The Fat Mod
Sounds like a winner to me
And if anyone knows, its the Wildman
Old 12-26-2006, 06:44 AM
rufushusky rufushusky is offline
Send a message via AIM to rufushusky
Amen! Got to check the rods.....upgraded HPOP would not be a bad idea either, upgraded HPOP, intake, exhaust, custom chip, BB turbo, hybrid injectors, upgraded lift pump and of courses GAUGES!!!!! should get you a safe and reliable 450rwhp, maybe even around 500rwhp.......however I did just list about $8k worth of stuff.......
Old 12-26-2006, 09:16 AM
Maintain Maintain is offline
sexy
Send a message via AIM to Maintain
You have PMR's. 400's about the limit
Old 12-26-2006, 10:27 AM
Depends on the build date, he may not have them if it was an early model
Old 12-26-2006, 01:12 PM
sexy
Sure does, if your build date is prevoius to 10/00 then there is a good chance you have forged rods.
There are also scant cases that I've seen where a build date of 08/00 had PMR's, while a truck with a build date of 01/01 had forged rods. I'd rather be safe then sorry and get that checked before you cross the 400hp mark. Sure, there are guys out there pushing 450hp/1000+tq on pmr's but do you want to be left with a $10,000 bill if one of them installs windows on your block?!
If I was a bettin' man, I'd say he has PMR's though...
Old 12-26-2006, 07:17 PM
Here is a list of what i have done to the truck so far Map sensor fooler,Intake, 4in. downpipe to 5in exh with stacks,fuel shim kit,wicked wheel,gauges tranny,pyro,boost I checked the rods they are pmr but have a set of forged just need to get them installed gonna order a chip from DP when I get a chance wondering what turbo,and who to get injectors from gonna do heavy towing and sled pulling just for kicks i tow anywhere from 30,000 gross to my maximum i have towed grossed at 43000 any other info u need more than glad to supply
Old 12-27-2006, 02:44 PM
sexy
You're a bit overweight at 30,000lbs if you have an F2 or 350.
Definately not trying to discourage you, but if you install rods, you need to do a bit more. I suggest some more research and hopefully you either plan on paying someone to do this or you have opened up a few motors before. If you're going to do all this and put rods in you should look at more hp then 450 - maybe 550, 600 to make it worth the money you're about to dump into that engine.
Old 12-28-2006, 02:39 PM
4xDesign 4xDesign is offline
thats alot of weight
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
